Re: zmNinja on Galaxy S5
Posted: Tue Mar 14, 2017 11:05 pm
by tominator
Logs for version:1.2.39 (android)
Mar 14, 2017 05:59 PM INFO retrieved pre-stored loginData on past pause: {"serverName":"192.168.1.8","username":"tjw_watcher",<password removed>,"fallbackConfiguration":"","url":"http://<server>","apiurl":"http://<server>/api","eventServer":"","maxMontage":"100","streamingurl":"http://<server>/cgi-bin","maxFPS":"3","montageQuality":100,"singleImageQuality":"100","monSingleImageQuality":"100","montageHistoryQuality":"50","useSSL":false,"keepAwake":true,"isUseAuth":true,"isUseEventServer":false,"disablePush":false,"eventServerMonitors":"","eventServerInterval":"","refreshSec":"2","refreshSecLowBW":8,"enableLogs":true,"enableDebug":true,"usePin":false,"pinCode":"","canSwipeMonitors":true,"persistMontageOrder":true,"onTapScreen":"Montage","enableh264":true,"gapless":false,"montageOrder":"","montageHiddenOrder":"","montageArraySize":"0","showMontageSubMenu":false,"graphSize":2000,"enableAlarmCount":true,"minAlarmCount":1,"montageSize":"3","useNphZms":true,"useNphZmsForEvents":true,"packMontage":false,"exitOnSleep":false,"forceNetworkStop":false,"defaultPushSound":false,"enableBlog":true,"use24hr":false,"packeryPositions":"","currentMontageProfile":"","packeryPositionsArray":{},"EHpackeryPositions":"","packerySizes":"","timelineModalGraphType":"all","resumeDelay":0,"language":"en","reachability":true,"forceImageModePath":false,"disableNative":false,"vibrateOnPush":true,"soundOnPush":true,"cycleMonitors":false,"cycleMontage":false,"cycleMontageInterval":10,"cycleMonitorsInterval":10,"enableLowBandwidth":false,"autoSwitchBandwidth":false,"disableAlarmCheckMontage":false,"useLocalTimeZone":true,"fastLogin":true,"followTimeLine":false,"timelineScale":-1,"hideArchived":false,"videoPlaybackSpeed":2,"enableGIFMP4":false,"enableStrictSSL":false,"enableSlowLoading":false}
Mar 14, 2017 05:59 PM DEBUG Does login need to hear the wizard? false
Mar 14, 2017 05:59 PM DEBUG PortalLogin: error authenticating "No servers reachable"
Mar 14, 2017 05:59 PM INFO Failed reachability on http://<server>/index.php with error {"data":null,"status":0,"config":{"method":"GET","transformRequest":[null],"transformResponse":[null],"timeout":15000,"url":"http://<server>/index.php","headers":{"Accept":"application/json, text/plain, */*"}},"statusText":""}
Mar 14, 2017 05:59 PM INFO Reachability test..http://<server>/index.php
Mar 14, 2017 05:59 PM INFO detected loop when 192.168.1.8 fallsback to
Mar 14, 2017 05:59 PM INFO reached end of chain loop
Mar 14, 2017 05:59 PM INFO Fallback of 192.168.1.8 is
Mar 14, 2017 05:59 PM INFO Adding to chain stack: 192.168.1.8>http://<server>
Mar 14, 2017 05:59 PM DEBUG zmAutoLogin: Inside auth-error emit
Mar 14, 2017 05:59 PM INFO zmAutologin Error null and status 0
Mar 14, 2017 05:59 PM DEBUG Latest post dated 2017-02-25 07:54:24 but you read 2017-03-13 20:17:08
Mar 14, 2017 05:59 PM DEBUG current version: 1.2.39 & available version 1.2.39
Mar 14, 2017 05:59 PM INFO Checking if reCaptcha is enabled in ZM...
Mar 14, 2017 05:59 PM INFO zmAutologin called
Mar 14, 2017 05:59 PM DEBUG Resetting zmCookie...
Mar 14, 2017 05:59 PM INFO Cancelling zmAutologin timer
Mar 14, 2017 05:59 PM DEBUG PIN code entered is correct, or there is no PIN set
Mar 14, 2017 05:59 PM DEBUG unlock called with check PIN=true
Mar 14, 2017 05:59 PM INFO not checking for touchID
Mar 14, 2017 05:59 PM INFO User credentials are provided
Mar 14, 2017 05:59 PM DEBUG Inside Portal login Enter handler
Mar 14, 2017 05:59 PM DEBUG Not changing bandwidth state, as auto change is not on
Mar 14, 2017 05:59 PM DEBUG getBandwidth() normalized it as: highbw
Mar 14, 2017 05:59 PM DEBUG Detected network type as: wifi
Mar 14, 2017 05:59 PM INFO Entering Portal Main
Mar 14, 2017 05:59 PM INFO >>>>>>>>>>>>>>> All init over, going to portal login
Mar 14, 2017 05:59 PM INFO >>>> Disabling strict SSL checking (turn off in Dev Options if you can't connect)
Mar 14, 2017 05:59 PM INFO DataModel init recovered this loginData as {"serverName":"192.168.1.8","username":"tjw_watcher",<password removed>,"fallbackConfiguration":"","url":"http://<server>","apiurl":"http://<server>/api","eventServer":"","maxMontage":"100","streamingurl":"http://<server>/cgi-bin","maxFPS":"3","montageQuality":100,"singleImageQuality":"100","monSingleImageQuality":"100","montageHistoryQuality":"50","useSSL":false,"keepAwake":true,"isUseAuth":true,"isUseEventServer":false,"disablePush":false,"eventServerMonitors":"","eventServerInterval":"","refreshSec":"2","refreshSecLowBW":8,"enableLogs":true,"enableDebug":true,"usePin":false,"pinCode":"","canSwipeMonitors":true,"persistMontageOrder":true,"onTapScreen":"Montage","enableh264":true,"gapless":false,"montageOrder":"","montageHiddenOrder":"","montageArraySize":"0","showMontageSubMenu":false,"graphSize":2000,"enableAlarmCount":true,"minAlarmCount":1,"montageSize":"3","useNphZms":true,"useNphZmsForEvents":true,"packMontage":false,"exitOnSleep":false,"forceNetworkStop":false,"defaultPushSound":false,"enableBlog":true,"use24hr":false,"packeryPositions":"","currentMontageProfile":"","packeryPositionsArray":{},"EHpackeryPositions":"","packerySizes":"","timelineModalGraphType":"all","resumeDelay":0,"language":"en","reachability":true,"forceImageModePath":false,"disableNative":false,"vibrateOnPush":true,"soundOnPush":true,"cycleMonitors":false,"cycleMontage":false,"cycleMontageInterval":10,"cycleMonitorsInterval":10,"enableLowBandwidth":false,"autoSwitchBandwidth":false,"disableAlarmCheckMontage":false,"useLocalTimeZone":true,"fastLogin":true,"followTimeLine":false,"timelineScale":-1,"hideArchived":false,"videoPlaybackSpeed":2,"enableGIFMP4":false,"enableStrictSSL":false,"enableSlowLoading":false}
Mar 14, 2017 05:59 PM INFO SlowDelay is: false
Mar 14, 2017 05:59 PM INFO Setting DataModel init bandwidth to: highbw
Mar 14, 2017 05:59 PM DEBUG timeline graph type not set. Setting to all
Mar 14, 2017 05:59 PM INFO user profile encrypted, decoding...
Mar 14, 2017 05:59 PM INFO Setting up pause and resume handler AFTER language is loaded...
Mar 14, 2017 05:59 PM INFO Setting up POST LOGIN timer
Mar 14, 2017 05:59 PM INFO Checking for news updates
Mar 14, 2017 05:59 PM INFO Checking for new version updates...
Mar 14, 2017 05:59 PM INFO No Event Server present. Not initializing
Mar 14, 2017 05:59 PM INFO ZMData init: checking for stored variables & setting up log file
Mar 14, 2017 05:59 PM INFO Language file loaded, continuing with rest
Mar 14, 2017 05:59 PM INFO >>>>Language to be used:en
Mar 14, 2017 05:59 PM INFO Device Language is:en
Mar 14, 2017 05:59 PM INFO No language set, switching to en
Mar 14, 2017 05:59 PM INFO App Version: 1.2.39
Mar 14, 2017 05:59 PM INFO Retrieving language before init is called...
Mar 14, 2017 05:59 PM INFO Enabling native transitions...
2017-03-14T22:59:04.559Z INFO Updating statusbar
2017-03-14T22:59:04.556Z INFO >>>>No data to import....
2017-03-14T22:59:04.389Z INFO Reachable: No server name configured, likely first use?
2017-03-14T22:59:04.351Z DEBUG zmAutoLogin: Inside auth-error emit
2017-03-14T22:59:04.350Z INFO zmAutologin Error null and status 0
2017-03-14T22:59:04.341Z INFO ZM has recaptcha disabled - good
2017-03-14T22:59:04.146Z DEBUG text zoom factor is 1
2017-03-14T22:59:04.060Z INFO Checking if reCaptcha is enabled in ZM...
2017-03-14T22:59:04.057Z INFO zmAutologin called
2017-03-14T22:59:04.052Z DEBUG Resetting zmCookie...
2017-03-14T22:59:04.040Z INFO Your network is online, re-authenticating
2017-03-14T22:59:04.030Z INFO localforage driver for storage:asyncStorage
2017-03-14T22:59:03.490Z INFO You are running on android
Mar 14, 2017 05:55 PM INFO ROOT APP:App is going into background
Mar 14, 2017 05:55 PM INFO retrieved pre-stored loginData on past pause: {"serverName":"192.168.1.8","username":"tjw_watcher",<password removed>,"fallbackConfiguration":"","url":"http://<server>","apiurl":"http://<server>/api","eventServer":"","maxMontage":"100","streamingurl":"http://<server>/cgi-bin","maxFPS":"3","montageQuality":100,"singleImageQuality":"100","monSingleImageQuality":"100","montageHistoryQuality":"50","useSSL":false,"keepAwake":true,"isUseAuth":true,"isUseEventServer":false,"disablePush":false,"eventServerMonitors":"","eventServerInterval":"","refreshSec":"2","refreshSecLowBW":8,"enableLogs":true,"enableDebug":true,"usePin":false,"pinCode":"","canSwipeMonitors":true,"persistMontageOrder":true,"onTapScreen":"Montage","enableh264":true,"gapless":false,"montageOrder":"","montageHiddenOrder":"","montageArraySize":"0","showMontageSubMenu":false,"graphSize":2000,"enableAlarmCount":true,"minAlarmCount":1,"montageSize":"3","useNphZms":true,"useNphZmsForEvents":true,"packMontage":false,"exitOnSleep":false,"forceNetworkStop":false,"defaultPushSound":false,"enableBlog":true,"use24hr":false,"packeryPositions":"","currentMontageProfile":"","packeryPositionsArray":{},"EHpackeryPositions":"","packerySizes":"","timelineModalGraphType":"all","resumeDelay":0,"language":"en","reachability":true,"forceImageModePath":false,"disableNative":false,"vibrateOnPush":true,"soundOnPush":true,"cycleMonitors":false,"cycleMontage":false,"cycleMontageInterval":10,"cycleMonitorsInterval":10,"enableLowBandwidth":false,"autoSwitchBandwidth":false,"disableAlarmCheckMontage":false,"useLocalTimeZone":true,"fastLogin":true,"followTimeLine":false,"timelineScale":-1,"hideArchived":false,"videoPlaybackSpeed":2,"enableGIFMP4":false,"enableStrictSSL":false,"enableSlowLoading":false}
Mar 14, 2017 05:55 PM DEBUG Does login need to hear the wizard? false
Mar 14, 2017 05:55 PM DEBUG PortalLogin: error authenticating "No servers reachable"
Mar 14, 2017 05:55 PM INFO Failed reachability on http://<server>/index.php with error {"data":null,"status":0,"config":{"method":"GET","transformRequest":[null],"transformResponse":[null],"timeout":15000,"url":"http://<server>/index.php","headers":{"Accept":"application/json, text/plain, */*"}},"statusText":""}
Mar 14, 2017 05:55 PM INFO Reachability test..http://<server>/index.php
Mar 14, 2017 05:55 PM INFO detected loop when 192.168.1.8 fallsback to
Mar 14, 2017 05:55 PM INFO reached end of chain loop
Mar 14, 2017 05:55 PM INFO Fallback of 192.168.1.8 is
Mar 14, 2017 05:55 PM INFO Adding to chain stack: 192.168.1.8>http://<server>
Mar 14, 2017 05:55 PM DEBUG zmAutoLogin: Inside auth-error emit
Mar 14, 2017 05:55 PM INFO zmAutologin Error null and status 0
Mar 14, 2017 05:55 PM INFO Error getting ZM logs:{"data":null,"status":0,"config":{"method":"GET","transformRequest":[null],"transformResponse":[null],"url":"http://<server>/api/logs.json?sort=TimeKey&direction=desc&page=1","headers":{"Accept":"application/json, text/plain, */*"}},"statusText":""}
Mar 14, 2017 05:54 PM INFO Checking if reCaptcha is enabled in ZM...
Mar 14, 2017 05:54 PM INFO zmAutologin called
Mar 14, 2017 05:54 PM DEBUG Resetting zmCookie...
Mar 14, 2017 05:54 PM INFO Cancelling zmAutologin timer
Mar 14, 2017 05:54 PM DEBUG PIN code entered is correct, or there is no PIN set
Mar 14, 2017 05:54 PM DEBUG unlock called with check PIN=true
Mar 14, 2017 05:54 PM INFO not checking for touchID
Mar 14, 2017 05:54 PM INFO User credentials are provided
Mar 14, 2017 05:54 PM DEBUG Inside Portal login Enter handler
Mar 14, 2017 05:54 PM INFO Entering Portal Main
Mar 14, 2017 05:54 PM DEBUG going to portal login
Mar 14, 2017 05:54 PM DEBUG Last State recorded:{"viewId":"ion34","index":0,"historyId":"ion3","backViewId":null,"forwardViewId":null,"stateId":"log","stateName":"log","url":"/log","canSwipeBack":true,"title":"zmNinja Logs"}
Mar 14, 2017 05:54 PM DEBUG LogCtrl: resume called, starting log timer
Mar 14, 2017 05:54 PM INFO Login screen resumed
Mar 14, 2017 05:54 PM INFO >>> Resume delayed for 0 ms, to wait for network stack...
Mar 14, 2017 05:54 PM INFO App is resuming from background
Mar 14, 2017 05:54 PM DEBUG LogCtrl: pause called, killing log timer
Mar 14, 2017 05:54 PM INFO Login screen going to background, saving data
Mar 14, 2017 05:54 PM INFO ROOT APP: Stopping network pull...
Mar 14, 2017 05:54 PM INFO ROOT APP:App is going into background
Mar 14, 2017 05:54 PM INFO Failed reachability on http://<server>/index.php with error {"data":null,"status":0,"config":{"method":"GET","transformRequest":[null],"transformResponse":[null],"timeout":15000,"url":"http://<server>/index.php","headers":{"Accept":"application/json, text/plain, */*"}},"statusText":""}
Mar 14, 2017 05:54 PM INFO Reachability test..http://<server>/index.php
Mar 14, 2017 05:54 PM INFO detected loop when 192.168.1.8 fallsback to
Mar 14, 2017 05:54 PM INFO reached end of chain loop
Mar 14, 2017 05:54 PM INFO Fallback of 192.168.1.8 is
Mar 14, 2017 05:54 PM INFO Adding to chain stack: 192.168.1.8>http://<server>
Mar 14, 2017 05:54 PM DEBUG zmAutoLogin: Inside auth-error emit
Mar 14, 2017 05:54 PM INFO zmAutologin Error null and status 0
Mar 14, 2017 05:54 PM DEBUG Logging out of current session...
Mar 14, 2017 05:53 PM INFO Not recovering login data as its empty
Mar 14, 2017 05:53 PM DEBUG Does login need to hear the wizard? false
Mar 14, 2017 05:53 PM INFO Error getting ZM logs:{"data":null,"status":0,"config":{"method":"GET","transformRequest":[null],"transformResponse":[null],"url":"http://<server>/api/logs.json?sort=TimeKey&direction=desc&page=1","headers":{"Accept":"application/json, text/plain, */*"}},"statusText":""}
