Ports to open for app to work
Discussion topics related to mobile applications for ZoneMinder
MoOz
Post by MoOz » Mon Mar 13, 2017 3:18 am
Hi I am using
ZM 1.30 and Ubuntu 16.04
and the ZmNinja app
the app works on the local LAN
but not from the WAN side
port 80 on my firewall is open to my zoneminder
do i have to open more ports ?
maybe i missed the document somewhere
asker
Re: Ports to open for app to work
Post by asker » Mon Mar 13, 2017 1:28 pm
The app doesn't need any additional ports.
If the app is working from LAN but not WAN, and you are using HTTPS, it is very likely an issue with your SSL certificate
https://github.com/pliablepixels/zmNinj ... use-wan-ip
MoOz
Post by MoOz » Tue Mar 14, 2017 5:53 am
Hi
thanks for your information and help
i am using HTTP
so i will turn on https
MoOz
Post by MoOz » Tue Mar 14, 2017 7:46 am
ok
i used this link to enable HTTPS
https://help.ubuntu.com/12.04/servergui ... figuration
sudo a2enmod ssl
sudo a2ensite default-ssl
sudo service apache2 restart
Https works from browser and app
MoOz
Post by MoOz » Tue Mar 14, 2017 7:55 am
for CERT used the link
created dir
sudo mkdir /etc/apache2/ssl
sudo openssl req -x509 -nodes -days 365 -newkey rsa:2048 -keyout /etc/apache2/ssl/zoneminder.key -out /etc/apache2/ssl/zoneminder.crt
edited the apache ssl config
restart
cannot connect with the app using Wan
work on the Lan
asker
Post by asker » Tue Mar 14, 2017 2:35 pm
1) Can you access ZM from WAN using a mobile browser?
2) If you can, please post zmNinja logs (debug logs - enable debug in dev options)
alfvicente
Post by alfvicente » Sat Mar 25, 2017 6:36 am
If you're using SSL try opening port 443 as well
