Auto Updates for Desktop Clients - HOWTO
Discussion topics related to mobile applications for ZoneMinder
jsylvia007
Post by jsylvia007 » Sun Feb 12, 2017 12:04 am
Howdy all!!
So I wanted a way to update zmNinja automatically without having to visit the web.
Nothing in the below is complicated, but sometimes it's nice to put the pieces together.
I used "download-github-release" from here: https://www.npmjs.com/package/download-github-release
This works on both Windows and Linux.
On linux (using Ubuntu as a sample here), issue:
sudo apt install nodejs nodejs-legacy npm
Once that's all installed, issue:
sudo npm install -g download-github-release
Once download-github-release is installed, you'd run it this way:
download-github-release -s linux64bit pliablepixels zmNinja /PATH/TO/WHERE/YOU/WANT
That's it! It will automatically download and unpackage it in a folder called "zmNinja-linux64bit" inside the above path. Just point your shortcut to the zmNinja executable in this place, and you're all set.
I then created a cron job to run the above command daily at 3am, but also put a shortcut to it on my desktop next to the app,
For Windows, you'll need to download Node.js from here: http://blog.teamtreehouse.com/install-n ... pm-windows
Once it's downloaded, run the executable to install Node.js.
Once installed, issue the same npm install command from above (this time without the sudo):
Once that's installed, you'd use this syntax:
C:\Users\YOUR_USERNAME\AppData\Roaming\npm\download-github-release.cmd -s win64 pliablepixels zmNinja C:\Users\YOUR_USERNAME\Documents
Anyway, hope this helps someone. I've been tinkering around with trying to get the "latest" release from Github, and it looks like this does the job perfectly so I thought I'd share with the community.
asker
Re: Auto Updates for Desktop Clients - HOWTO
Post by asker » Sun Feb 12, 2017 12:12 pm
Thanks for your contribution - looks interesting. One tweak you might consider is not to download it if the version is the same. I suppose I could add some command line parameters to zmninja which lets you check that easily. I'll work on it.
jsylvia007
Post by jsylvia007 » Sun Feb 12, 2017 2:48 pm
asker wrote:Thanks for your contribution - looks interesting. One tweak you might consider is not to download it if the version is the same. I suppose I could add some command line parameters to zmninja which lets you check that easily. I'll work on it.
Interesting concept! I don't know much about git, but I'm sure that there's a way for me to check what the "release" version is...
asker
Post by asker » Sun Feb 12, 2017 4:49 pm
Yes, you can easily get the latest release # using
https://api.github.com/repos/pliablepixels/zmNinja/releases/latest
And then read the "tag_name" parameter
You will however have to figure out which version you currently have, programatically. Probably just write a "version" file each time you download and install, till I add a command line parameter to query zmninja itself
jsylvia007
Post by jsylvia007 » Sun Feb 12, 2017 7:13 pm
So... Here is a linux script updated that will create a version file based on the version it downloads. This means it will download at least one time, but won't continue to re-download.
I will work on a Windows one... but I'm not so good with PowerShell, and it looks like that might be required.
We'll see!
#!/bin/bash
if [ "$#" -gt 1 ]; then
    echo "This Script only takes '-q' as an argument, should you not want any output."
    exit 0
fi
##below function comes from here: http://ask.xmodulo.com/compare-two-version-numbers.html
function version_gt() { test "$(echo "$@" | tr " " "\n" | sort -V | head -n 1)" != "$1"; }
DEST_DIR=$HOME/Documents/
DEST_VERSION="zmNinja-linux64bit"
INSTALL_DIR=$DEST_DIR$DEST_VERSION
if [ -f $INSTALL_DIR/version.txt ]; then
	INSTALLED_VERSION=`cat $INSTALL_DIR/version.txt`
else
	INSTALLED_VERSION=0
fi
LATEST_RELEASE=$(curl -L -s -H 'Accept: application/json' https://github.com/pliablepixels/zmNinja/releases/latest)
LATEST_VERSION=$(echo $LATEST_RELEASE | sed -e 's/.*"tag_name":"\(.*\)".*/\1/')
LATEST_VERSION=$(echo $LATEST_VERSION | sed 's/["].*$//')
LATEST_VERSION=${LATEST_VERSION#?}
if [ "$1" != "-q" ]; then
	echo $DEST_DIR
	echo $DEST_VERSION
	echo $INSTALL_DIR
	echo $INSTALLED_VERSION
fi
if version_gt $LATEST_VERSION $INSTALLED_VERSION; then
		echo "Update Required, Updating..."
	fi
	download-github-release -s $DEST_VERSION pliablepixels zmNinja $DEST_DIR
	echo "$LATEST_VERSION" > $INSTALL_DIR/version.txt
		echo "Update Completed."
	fi
else
		echo "No Update is Required."
	fi
fi
asker
Post by asker » Mon Feb 13, 2017 2:34 pm
nice!
jsylvia007
Post by jsylvia007 » Mon Mar 06, 2017 12:13 am
Finally got around to making the Windows script. Tested on Windows 10. Note that it does require node.JS from the previous post, but just in case...
jsylvia007 wrote:Howdy all!!
Once installed, open a command prompt, and issue the same npm install command from above:
Once it's all installed, you can create a scheduled task with this VBS Script...
' updateZMNinja.vbs
' Script to Update zmNinja
' Author Jacob D. Sylvia (Jacob.Sylvia@gmail.com) https://www.jacobsylvia.com/
' Version 0.1 - 05 MAR 2017
'VERSION COMPARE FUNCTION FROM HERE, and heavily modified:
'http://www.ozgrid.com/forum/showthread.php?t=61514
Function VersionCompare (Version1, Version2)
	'returns 1 if Version 1 is newer
    'returns -1 if version 1 is older
    'returns 0 if both versions are the same
    Dim i, k
    Dim Version1Array
    Dim Version2Array
    Version1Array = Split(Version1, ".")
    Version2Array = Split(Version2, ".")
    k = UBound(Version1Array)
    If UBound(Version2Array) < k Then k = UBound(Version2Array)
    For i = 0 To k
        'msgbox Version1Array(i)
		If CInt(Version1Array(i)) > Cint(Version2Array(i)) Then
            VersionCompare = 1
            Exit For
        ElseIf CInt(Version1Array(i)) < CInt(Version2Array(i)) Then
            VersionCompare = -1
            Exit For
        Else
            If UBound(Version1Array) = UBound(Version2Array) Then
                VersionCompare = 0
            ElseIf UBound(Version1Array) > UBound(Version2Array) Then
                VersionCompare = 1
            Else
                VersionCompare = -1
            End If
        End If
    Next
End Function
Dim DEST_DIR
Dim DEST_VERSION
Dim INSTALL_DIR
Dim INSTALLED_VERSION
Dim FSO
Set FSO = CreateObject("Scripting.FileSystemObject")
DEST_DIR = CreateObject("WScript.Shell").ExpandEnvironmentStrings("%USERPROFILE%") & "\Documents\Utilities\"
DEST_VERSION = "zmNinja-win64bit"
INSTALL_DIR= DEST_DIR & DEST_VERSION
'msgbox INSTALL_DIR
If FSO.FileExists(INSTALL_DIR & "\version.txt") Then
    Set file = FSO.OpenTextFile(INSTALL_DIR & "\version.txt", 1)
	content = file.ReadAll
	If (Left(content, 1) = "v") Then
		INSTALLED_VERSION = Right(content, len(content)-1)
	Else
		INSTALLED_VERSION = content
	End If
Else
	INSTALLED_VERSION=0
End If
'msgbox "Installed Version - " & INSTALLED_VERSION
set xmlhttp = CreateObject("MSXML2.ServerXMLHTTP.6.0")
xmlhttp.open "get", "https://github.com/pliablepixels/zmNinja/releases/latest", false
xmlhttp.send
'msgbox xmlhttp.responseText
strOutput = split(xmlhttp.responseText,"<title>")(1)
strOutput = split(strOutput,"</title>")(0)
strOutput = split(strOutput," ")(1)
LATEST_VERSION = Right(strOutput, len(strOutput)-1)
'msgbox "LATEST VERSION - " & LATEST_VERSION
comparison = VersionCompare (INSTALLED_VERSION, LATEST_VERSION)
'msgbox comparison
If (comparison = -1) Then
	'msgbox "There is a newer version..."
	execString = CreateObject("WScript.Shell").ExpandEnvironmentStrings("%USERPROFILE%") & "\AppData\Roaming\npm\download-github-release.cmd -s win64 pliablepixels zmNinja " & DEST_DIR
	'msgbox execString
	Set oShell = CreateObject ("WScript.Shell")
	oShell.run execString, DontShowWindow, WaitUntilFinished
	Set objFSOOut=CreateObject("Scripting.FileSystemObject")
	outFile=INSTALL_DIR & "\version.txt"
	Set objFileOut = objFSOOut.CreateTextFile(outFile,True)
	objFileOut.Write LATEST_VERSION
	objFileOut.Close
End If
Wscript.Quit
Also -
asker wrote:nice!
I noticed that you create a "version" file now, which is awesome... For some reason, it's not updating though. The most recent version is 1.2.39, but the contents of "version" is still 1.2.5... Thought you'd like to know.
Hope these scripts help everyone out!
asker
Post by asker » Mon Mar 06, 2017 4:32 pm
Ah, sorry, I forgot I added the file and did not update my desktop script to re-generate it.fixed it.
