I have an ODROID U3 that I would like to try zmNinja on. I installed Android 4.0.3 on an SD card which works fine. However, I can't install zmNinja from the Play Store because it says "This version isn't compatible with your device".
Does anyone know why the compatibility message is being shown? How can I determine what hardware/software combinations the Android port is compatible with?
zmNinja Android: This version isn't compatible with your device
Re: zmNinja Android: This version isn't compatible with your device
I think 4.0.3 might be too old.
Is it possible to use at least 4.4 ?
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
