user with low privilages cannot login via zmNinja?
linforpros
Post by linforpros »
Is this by design that if a user has minimal previleges in zoneminder he cannot use zmNinja?
In the above case only 'STREAM' and 'EVENTS' are allowed for user zmview.
If you try to login via zmNinja with its credentials it will fail with error.
Thanks for any hints
best regards
LinforPros
asker
Re: user with low privilages cannot login via zmNinja?
Post by asker »
This is more a function of ZM APIs. Which version of ZM are you using and what is the exact debug log error from zmNinja?
Note that you need to assign monitor view rights as well, otherwise the APIs won't be able to retrieve monitor status.
Here is a limited user that works with zmNinja. Make sure you are on 1.29 (or later) of ZM
Screen Shot 2016-06-12 at 9.40.07 AM.png (59.12 KiB) Viewed 2305 times
Please read before posting:
ES docs
zmNinja docs
