Page 1 of 1
Everything works but timeline
Posted: Sun Apr 03, 2016 9:06 pm
by iitywygms
I have nmninja working on linux, windows just great.
Installed on my android. 5.1 Everything works except timeline. When I click on something in the graph, it says showing event, but the screen just stays black. It is this way on my android tablet and phone.
Live view, events montage, and events display properly.
Is this a setting or something I am missing on android?
Re: Everything works but timeline
Posted: Sun Apr 03, 2016 9:57 pm
by asker
iitywygms wrote:I have nmninja working on linux, windows just great.
No, this should work out of the box.
Please enable Debug logs in zmninja (developer options) and please send me the output - you can email directly from the app in the logs menu
Posted: Mon Apr 04, 2016 3:23 pm
by iitywygms
Email sent. Thank you!
Posted: Mon Apr 04, 2016 3:55 pm
by asker
iitywygms wrote:Email sent. Thank you!
The logs you sent me show you started the app and went to montage. Your note above talked about the timeline - can you go to the timeline and then send me logs ? My understanding is that the timeline screen is where you are reporting a problem. It is also easier to make sure we are on the page page if you join the #zoneminder irc channel
Posted: Mon Apr 04, 2016 8:54 pm
by iitywygms
strange. I went to the timeline tab and tried to view a event before I sent the logs.
When I open the app it opens in the montage page.
I then click on timeline tab. In the timeline window I click on a section of time. It opens a window with "showing event" at the top of the screen.
But nothing is displaying or showing, just a black screen.
I just did this again and will send new log now.
"join the #zoneminder irc channel"
If you have a link or something I will do so. Sorry but not sure what a irc channel is :oops:
Posted: Tue Apr 05, 2016 12:15 am
by asker
just pushed 1.1.4 - I broke this part in 1.1.3
Posted: Tue Apr 05, 2016 1:56 am
by iitywygms
Fixed. Thank you.
