Restrict monitors to specific users
I have tried a couple of settings to restrict the monitors users can see, in the desktop version, and have not had success.
In ZM options for user I have
Enabled yes
Stream view
Events view
Control None
Monitors View
Groups None
System None
Bandwidth Low
Monitor (the 4 chosen monitors to allow)
zmNinja does log in with the user/password but the Montage view displays the 10 monitor names with question marks and no video stream.
bb
asker
Re: Restrict monitors to specific users
Post by asker »
bbunge, that is correct - the current implementation of the API does not honor user roles. As long as you are logged in, you have full access to all monitors. This is a good feature to have and I'll investigate what it takes to modify the APIs. Once the APIs are modified, zmNinja will automatically behave the way you want.
Please read before posting:
ES docs
zmNinja docs
