zmNinja, ES+ML support discontinuation notice (in advance) : EOY 2021
Elliott-shep
Re: zmNinja, ES+ML support discontinuation notice (in advance) : EOY 2021
Post by Elliott-shep »
Thanks for the zmNinga app.
Rajstopy
Post by Rajstopy »
ZMNinja is a really good app, I use it daily to get a look on my cameras.
Thank you so much for your great job overs those years.
I'm sure disappointed to learn this app will be discontinued, but I hope someone will take over...
Good luck !
mlu
Post by mlu »
Hi all, do you know if zmNinja development and FCM cloud function have been picked up by someone? Or should be expect zmNinja notifications to stop working sometime soon?
SteveGilvarry
Post by SteveGilvarry »
Zoneminder Dev Team has taken it on, Isaac and myself, anyone else with experience is welcome to help. If you check Play Store you will see Android is already transferred, we are working on completing the transfer across at the moment, and building the new versions with our FCM Notification service.
iOS will be a pain as Apple prevents a transfer for any apps using iCloud Entitlements so Apple users will need to download a new App once we can get it published.
There is a PR in ZMES with our new FCM server details, but it has to go live with the apps so it is currently waiting for the apps to be ready. I am literally working on an iOS build right now. Hopefully Asker will give us some leeway as he is nice guy :D
dtemp132
Post by dtemp132 »
I know this isn't the correct place to put this, but with the software moving around and changing hands, can someone please tell me the proper way to report a security vulnerability with the iOS app? I would assume this vulnerability would carry over to the "new" iOS app mentioned in the last comment if they are copy/pasting large portions of the code.
I'd say Slack for the moment.
pat2
Post by pat2 »
Thanks a lot to have developed this great app. Using it on IOS, Android, Windows, Ubuntu.
https://github.com/zoneminder/zmninja/releases
Thanks a lot, asker/pliablepixels !
ZM 1.36.34 - 14 cameras on Orange Pi 5 (arm64) - Ubuntu Jammy 22.04
achaji3
Post by achaji3 »
What is the minimum supported version of ZoneMinder, Android and iOS? zmNinja Help;
myfiosgateway.com
mobdro
kaltertod
Post by kaltertod »
achaji3 wrote: Thu Jul 14, 2022 12:10 pm What is the minimum supported version of ZoneMinder, Android and iOS? zmNinja Help;
I believe it is supported with zoneminder 1.32+ However future support after development stopped on ZMES is not guaranteed.
foytech
Post by foytech »
I just bought this app and it doesn’t work. Any chance I can get my money back!
What doesn't work about it?
You should be able to get a refund through the apple store.
foytech
Post by foytech »
Sorry, Just now seeing this. It is now working. I had a problem with the streaming, and have since corrected it with the help of one of these posts... The path to the CGI was incorrect, I had to make a slight modification to get it to start streaming. It is indeed a great app.
aquadot
Post by aquadot »
Any chance you'd want to try getting this into F-droid?
https://f-droid.org/forums/topic/zmninj ... r-android/
Not really. We can likely fix the licensing but I don't think anyone wants to take on the build pain.
We do already provide .apks.
