MJPEG over RTSP
henryco
MJPEG over RTSP
Post by henryco »
I have converted a webcam into an ip-camera using gstreamer : with gstreamer i create a rtsp server that makes direectly available the webcam MJPG video format (not the raw format compressed in h264 !) for any IP connection. So i'm wondering if it's possible to get this in zoneminder and if yes with what configuration : because it's rtsp but not h264, i guess it's source type = remote and remote protocol = rtsp in zoneminder , right ? but then i'm not sure about the remaining fields.
when i had h264 over rtsp i just needed source type = Ffmpeg and source path = rtsp://192.168.1.38:8554/test and it worked
but now there are many more fields and i can't make it work with the remote host path rtsp://192.168.1.38:8554/test
thank you for any help
