Network Triggers Don't Work After Reboot
I'm running v1.28.1 on an Ubuntu server and recently enabled OPT_TRIGGERS so that zmtrigger.pl would run and I could trigger monitoring via TCP. It was working fine until the server was shut down (sudo init 0) and powered back on. At that point, zmtrigger.pl was running and accepting connections, but it was not triggering recording when commands to do so were sent to it. I restarted ZoneMinder (sudo /etc/init.d/zoneminder restart) and the issue was resolved. I searched the forums and this unanswered post is the only similar thing I found. Can anyone help me make sure the trigger script works correctly at boot without intervention in the future?
