Android IP Camera blue screen
Nem
Post by Nem » Sun Feb 14, 2016 6:28 am
I have ZM running on my server with IP camera app on my android (Nexus 5x)
I have added the monitor with precisely these instructions on the IP webcam page:
General:
Source type: Remote
Function: Monitor
Source:
Protocol: HTTP
Method: Simple
Host name: 192.168.187.88
Port: 8080
Remote host path: /video (just "video" doesn't work).
Note: If necessary, specify your username in password in URL, like this: username:password@192.168.187.88.
I can view the stream when I navigate to 192.168.187.88:8080 (a feature of ip webcam)
I can also access the network stream on VLC
But when I try to view the video on zoneminder I just get a bluescreen
Is there a setting I missed somewhere?
marco123
Re: Android IP Camera blue screen
Post by marco123 » Wed Feb 17, 2016 7:39 am
i've tested ip webcam for android !
it work fine with zominder ...
my setup :
General:
Source type: Remote
Function: Monitor
Source:
Protocol: HTTP
Method: Simple
Host name: 192.168.x.x ( no password, no username )
Port: 8081 ( i use 8080 for another cam )
Target Colorspace: 24b
320/240 , 640/480, 1280/720
with firefox : 192.168.x.x:8081 it's ok
Capture Width and Capture Height are same in ip webcam AND zominder
Nem
Post by Nem » Wed Feb 17, 2016 7:56 am
The only difference between our setups is that I use a username a password (set as per the docs)
I've tried turning the user/pass off in IP camera, but I still get a blue screen
What phone are you using?
marco123
Post by marco123 » Wed Feb 17, 2016 11:09 am
samsung core prime .
ocascante
Post by ocascante » Wed Jun 29, 2016 1:30 am
I have the same problem with my samsung galaxy s6.
In zoneminder logs, have "unable to decode jpeg" error.
esprit1st
Post by esprit1st » Sat Dec 17, 2016 11:52 pm
No picture here with the same settings and with and without password.
esprit1st
Post by esprit1st » Sun Dec 18, 2016 12:32 am
So I got it to work. The problem was that the Server, that ZM is running on was not able to access the IP address even though it is the same network.
I don't know why it didn't see it, since my desktop did immediately, however after restarting the Server and making sure it was able to access the android IP camera using the browser, ZM worked just fine.
Seems like Linux had a problem discovering the added device/IP address.
AndyMcc
Post by AndyMcc » Fri Aug 17, 2018 4:36 am
Make sure your video resolution in IP Camera is set to the same as in the Source tab for the monitor.
This resolves the blue screen, and setting it back to something not matching will bring the blue screen back instantly.
