Single cam view no longer works
JRoque
Post by JRoque » Mon Dec 21, 2015 3:38 pm
Hi. I recently upgraded to 1.28.1 delivered through Ubuntu and I can longer see a single camera monitor. Both montage and cycle work fine but clicking on a single monitor pops up a window, showing the events, etc but no video. This used to work fine until 2 days ago when I upgraded from an earlier build of 1.28 and also applied the latest ubuntu 12.04 security updates. Any hints on where to look? Any settings that might have changed within ZM from previous versions of 1.28?
Thanks,
JR
JRoque
Re: Single cam view no longer works
Post by JRoque » Wed Dec 23, 2015 1:06 am
Hi. Just tested this again and have narrowed things a bit, though having done any debugging - hoping someone else has seen a similar issue.
I went back to my previous build with v1.28.0 and everything works fine. I upgraded the normal OS/security stuff (kernel, etc) while leaving ZM at v1.28.0 and all is well. This narrows it down to upgrading v1.28.0 to v1.28.1. It might be as simple as a new setting or the like since montage works fine.
Thanks,
JR
Users browsing this forum: No registered users and 8 guests
