I got an error when I ran /usr/bin/zmupdate.pl to upgrade my database.
Ubuntu 14.04-3 64 bit system
Upgrading database to version 1.28.109
Loading config from DB
Saving config to DB
DBD::mysql::db do failed: Access denied for user 'zmuser'@'localhost' to database 'zm' at /usr/share/perl5/ZoneMinder/ConfigAdmin.pm line 135, <STDIN> line 2.
Can't lock Config table: Access denied for user 'zmuser'@'localhost' to database 'zm' at /usr/bin/zmupdate.pl line 498.
Issuing rollback() due to DESTROY without explicit disconnect() of DBD::mysql::db handle database=zm;host=localhost at /usr/share/perl/5.18/Carp.pm line 100, <STDIN> line 2.
I got around the error by dropping the zm database and installing a fresh copy
Database Upgrade Error 1.28.107 to 1.28.109
Re: Database Upgrade Error 1.28.107 to 1.28.109
I did too today, I think I went to phpmyadmin and the privileges were reduced for zmuser, so I edited it and applied all.
I also had a version mismatch error so I installed again uping .108 to .109. so after I fixed zmuser I ran zmupdate.pl
The best I can remember
Jimmy
Jimmy
Linux Mint 21 Cinnamon Mariadb 10.6.x using Master 1.37.x latest always
- knight-of-ni
So either the Config table was open by some other process (did you stop zoneminder?)Can't lock Config table: Access denied for user 'zmuser'@'localhost' to database 'zm' at /usr/bin/zmupdate.pl line 498.
or your zmuser account does not have mysql "lock" permission assigned to it.
zm was stopped
lack of "lock" likely it
Should input?
mysql -e "grant select,insert,update,delete,create,lock on zm.* to 'zmuser'@localhost identified by 'zmpass';"
Will try again tomorrow.
Should input?
I ran into the same errors with the fix by ending up dropping the database and creating new. Upgrade 1.28.108 > 1.28.109I got an error when I ran /usr/bin/zmupdate.pl to upgrade my database.
Upgrade worked the second time. MySQL permissions should be:
mysql -e "grant select,insert,update,delete,create,alter,lock tables on zm.* to 'zmuser'@localhost identified by 'zmpass';"
Upgrade procedures at:
https://wiki.zoneminder.com/Common_Issu ... _on_Ubuntu
- knight-of-ni
Bill,
As of 1.28.109, you need to add "index" to the set of mysql permissions.
Will go back and try it again.....
bb
bb
2nd test upgrade. I needed the lock tables and alter to get the database upgrade to work. So, with index added the command is:
mysql -e "grant select,insert,update,delete,create,alter,lock tables,index on zm.* to 'zmuser'@localhost identified by 'zmpass';"
