Service not starting on Boot
DVB Hardware
Post by DVB Hardware »
For some reason Zonminder has mysteriously stoped booting on power up.
I haven't touched anything and and has been working fine for 2 days booting on and off on a test box using 1.28.107.
I changed sleep 15 to 30 just to test but no good
Have to start zoneminder in the console.
I would re-install but waiting for 1.28.107 is back in the ppa
Linux Mint 21 Cinnamon Mariadb 10.6.x using Master 1.37.x latest always
Re: Service not starting on Boot
Would guess you are using Ubuntu 14.04? Can you start ZM from the web gui?
bb
DVB Hardware
Yes, but mint 17.2
aaronl
Post by aaronl »
What does syslog say?
DVB Hardware
In the GUI... nothing, service never started
aaronl
Post by aaronl »
open a terminal and do
tail -f /var/log/syslog
while you try to start it. What does it tell you is happening?
DVB Hardware
Cannot run that on power on boot, however starting zoneminder it from the GUI shows no errors
Cold boot, zonminder Gui show disabled and should be running
System log shows no reference to zoneminder starting on a cold boot
I set up that version of Mint with ZM 1.26.5 and upgraded to 1.28.107 and it started every time on boot.
bb
DVB Hardware
It was working for 3 days and just stopped for no reason at all, did not touch anything.
Since I am running 1.25.107 I will just downgrade to 1.28.1 since the 107 is missing from the ppa
UPDATE: I guess I did edit sleep it was in all caps not lowercase.
Solved !
Well done! Will have to keep that one in the memory banks for future use.
If you want to go back to 1.28.107 it is in the zoneminder-master PPA. However, the zoneminder-master PPA contains BETA releases which are recommended for testing purposes only! As in all things BETA there will be things that may not work right!
DVB Hardware
I went back to 1.28.1 so much smoother install, basically no errors in the log compared to 107
Thanks so much for your help bb
