Hi asker,
sorry for less information provided, but meanwhile I did some other test, and rebooted all server, Zoneminder and Openhab.
After reboot, seems API working from both, browser and curl.
I did more test this evening, and I'll keep you updated.
Regards
Marco
Set function from API does not work
Re: Set function from API does not work
Production Zoneminder 1.31.4 Ubuntu 16.04 LTS on VmWare ESXi
6 Cameras FOSCAM FI8918W
OpenHab Integration
OpenHab Integration
Hi asker,
all working fine now. I have last version of ZM and API, authentication works, and I can control my ZM from OpenHab.
Now I'm back on original issue, the funcion does not work due a bug in MonitorsController.php.
Here is my version of the file, can you help me to add daemon controller?
<?php
App::uses('AppController', 'Controller');
* Monitors Controller
* @property Monitor $Monitor
* @property PaginatorComponent $Paginator
class MonitorsController extends AppController {
* Components
* @var array
public $components = array('Paginator', 'RequestHandler');
* index method
* @return void
public function index() {
$this->Monitor->recursive = 0;
$monitors = $this->Monitor->find('all');
$this->set(array(
'monitors' => $monitors,
'_serialize' => array('monitors')
* view method
* @throws NotFoundException
* @param string $id
* @return void
public function view($id = null) {
if (!$this->Monitor->exists($id)) {
throw new NotFoundException(__('Invalid monitor'));
$options = array('conditions' => array('Monitor.' . $this->Monitor->primaryKey => $id));
$monitor = $this->Monitor->find('first', $options);
$this->set(array(
'monitor' => $monitor,
'_serialize' => array('monitor')
* add method
* @return void
public function add() {
if ($this->request->is('post')) {
$this->Monitor->create();
if ($this->Monitor->save($this->request->data)) {
$this->daemonControl($this->Monitor->id, 'start', $this->request->data);
return $this->flash(__('The monitor has been saved.'), array('action' => 'index'));
* edit method
* @param string $id
* @return void
public function edit($id = null) {
$this->Monitor->id = $id;
$message = 'Saved';
} else {
$message = 'Error';
$this->set(array(
'message' => $message,
'_serialize' => array('message')
* delete method
* @param string $id
* @return void
public function delete($id = null) {
if (!$this->Monitor->exists()) {
$this->request->allowMethod('post', 'delete');
$this->daemonControl($this->Monitor->id, 'stop');
if ($this->Monitor->delete()) {
return $this->flash(__('The monitor has been deleted.'), array('action' => 'index'));
} else {
return $this->flash(__('The monitor could not be deleted. Please, try again.'), array('action' => 'index'));
public function sourceTypes() {
$sourceTypes = $this->Monitor->query("describe Monitors Type;");
preg_match('/^enum\((.*)\)$/', $sourceTypes[0]['COLUMNS']['Type'], $matches);
foreach( explode(',', $matches[1]) as $value ) {
$enum[] = trim( $value, "'" );
$this->set(array(
'sourceTypes' => $enum,
'_serialize' => array('sourceTypes')
// Check if a daemon is running for the monitor id
public function daemonStatus() {
$id = $this->request->params['named']['id'];
$daemon = $this->request->params['named']['daemon'];
$monitor = $this->Monitor->find('first', array(
'fields' => array('Id', 'Type', 'Device'),
'conditions' => array('Id' => $id)
// Clean up the returned array
$monitor = Set::extract('/Monitor/.', $monitor);
// Pass -d for local, otherwise -m
if ($monitor[0]['Type'] == 'Local') {
$args = "-d ". $monitor[0]['Device'];
} else {
$args = "-m ". $monitor[0]['Id'];
// Build the command, and execute it
$zm_path_bin = Configure::read('ZM_PATH_BIN');
$command = escapeshellcmd("$zm_path_bin/zmdc.pl status $daemon $args");
$status = exec( $command );
// If 'not' is present, the daemon is not running, so return false
// https://github.com/ZoneMinder/ZoneMinder/issues/799#issuecomment-108996075
// Also sending back the status text so we can check if the monitor is in pending
// state which means there may be an error
$statustext = $status;
$status = (strpos($status, 'not')) ? false : true;
$this->set(array(
'status' => $status,
'statustext' => $statustext,
'_serialize' => array('status','statustext'),
public function daemonControl($id, $command, $monitor=null, $daemon=null) {
$args = '';
$daemons = array();
if (!$monitor) {
// Need to see if it is local or remote
'fields' => array('Type', 'Function'),
$monitor = $monitor['Monitor'];
if ($monitor['Type'] == 'Local') {
$args = "-d " . $monitor['Device'];
} else {
$args = "-m " . $id;
if ($monitor['Function'] == 'Monitor') {
array_push($daemons, 'zmc');
} else {
array_push($daemons, 'zmc', 'zma');
foreach ($daemons as $daemon) {
$shellcmd = escapeshellcmd("$zm_path_bin/zmdc.pl $command $daemon $args");
$status = exec( $shellcmd );
OpenHab Integration
OpenHab Integration
Hi @asker,
finally it seems I have fixed. Let me know if my code is fine and Can you add this to ZM code? may I have to open an issue on git?
$message = 'Saved';
} else {
$message = 'Error';
$this->set(array(
//I added Line Below
$this->daemonControl($this->Monitor->id, 'restart');
OpenHab Integration
OpenHab Integration
Hi @asker,
unfornunately my code does not work.
When I setup Function to "Monitor" via API, the monitor still continue to record on motion.
Please let me know what you need to troubleshoot.
Regards
Regards
OpenHab Integration
OpenHab Integration
Please change your line to
I tested and it works - just refresh your web console and you will see the monitor has been updated. If you monitor your logs you will also see that your monitor restarts correctly.
$this->daemonControl($this->Monitor->id, 'restart', $this->request->data);
marcolino7 wrote:Hi @asker,
Regards
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
I got something like that:
it seems a restart of daemon for monitor with id 1.
I'll keep under monitor.
Marco
2015-09-28 17:41:58.143934 zma_m1 9960 INF In mode 2/0, warming up zma.cpp 142
2015-09-28 17:41:58.083790 zmdc 9960 INF 'zma -m 1' started at 15/09/28 17:41:58 zmdc.pl
2015-09-28 17:41:58.083780 zmdc 1186 INF 'zma -m 1' starting at 15/09/28 17:41:58, pid = 9960 zmdc.pl
2015-09-28 17:41:58.078040 zmdc 1186 INF Starting pending process, zma -m 1 zmdc.pl
2015-09-28 17:41:58.012956 zmc_m1 9959 INF Starting Capture version 1.28.106 zmc.cpp 250
2015-09-28 17:41:57.965330 zmdc 1186 INF 'zma -m 1' exited normally zmdc.pl
2015-09-28 17:41:57.948209 zma_m1 9602 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2015-09-28 17:41:57.943270 zmdc 1186 INF 'zma -m 1' sending stop to pid 9602 at 15/09/28 17:41:57 zmdc.pl
2015-09-28 17:41:57.908340 zmdc 9959 INF 'zmc -m 1' started at 15/09/28 17:41:57 zmdc.pl
2015-09-28 17:41:57.908310 zmdc 1186 INF 'zmc -m 1' starting at 15/09/28 17:41:57, pid = 9959 zmdc.pl
2015-09-28 17:41:57.900420 zmdc 1186 INF Starting pending process, zmc -m 1 zmdc.pl
2015-09-28 17:41:57.810104 zma_m2 9954 INF In mode 2/0, warming up zma.cpp 142
2015-09-28 17:41:57.788180 zmdc 1186 INF 'zmc -m 1' exited normally zmdc.pl
Marco
OpenHab Integration
OpenHab Integration
