The 2 camera's are recording, and I can see the stills. But no video. I only see a frame with a broken image upper left corner.
It was working great before I installed this version.
Sorry for my bad english....
Here's som log:
2015-09-04 14:44:53.936420 web_js 3256 ERR getCmdResponse stream error: socket_sendto( /var/run/zm/zms-343555s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=event
2015-09-04 14:44:53.881435 web_js 4228 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-622285s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2015-09-04 14:44:53.872982 web_php 3256 ERR socket_sendto( /var/run/zm/zms-343555s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:44:53.801828 web_php 4228 ERR socket_sendto( /var/run/zm/zms-622285s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:44:53.800503 web_php 2590 ERR socket_sendto( /var/run/zm/zms-645960s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:44:53.499864 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 51 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:44:53.465945 zmc_m1 2395 ERR Error while decoding frame 62959 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:44:48.391257 web_php 2587 ERR socket_sendto( /var/run/zm/zms-825244s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:44:47.983965 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 4f 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:44:47.923750 zmc_m1 2395 ERR Error while decoding frame 62909 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:44:42.417427 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 4d 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:44:42.383581 zmc_m1 2395 ERR Error while decoding frame 62859 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:44:41.945298 web_js 2587 ERR getCmdResponse stream error: socket_sendto( /var/run/zm/zms-343555s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=event
2015-09-04 14:44:41.872896 web_php 2587 ERR socket_sendto( /var/run/zm/zms-343555s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:44:40.445741 web_js 2586 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-622285s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2015-09-04 14:44:40.378400 web_php 2586 ERR socket_sendto( /var/run/zm/zms-622285s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:44:38.172403 web_php 2586 ERR socket_sendto( /var/run/zm/zms-645960s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:44:36.873742 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 4b 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:44:36.843848 zmc_m1 2395 ERR Error while decoding frame 62809 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:44:36.325275 web_php 2587 ERR socket_sendto( /var/run/zm/zms-825244s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:44:31.311787 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 49 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:44:31.263727 zmc_m1 2395 ERR Error while decoding frame 62759 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:44:28.377969 web_js 2698 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-622285s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2015-09-04 14:44:28.202669 web_php 2698 ERR socket_sendto( /var/run/zm/zms-622285s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:44:26.106941 web_php 2698 ERR socket_sendto( /var/run/zm/zms-645960s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:44:25.747711 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 47 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:44:25.704001 zmc_m1 2395 ERR Error while decoding frame 62709 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:44:24.143619 web_js 2702 WAR Adjusting to minimum width when getting popup size for tag 'watch' - getPopupSize() ?view=montage
2015-09-04 14:44:24.103184 web_php 2694 ERR socket_sendto( /var/run/zm/zms-825244s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:44:20.346497 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 45 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:44:20.143895 zmc_m1 2395 ERR Error while decoding frame 62659 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:44:14.606673 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 43 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:44:14.564468 zmc_m1 2395 ERR Error while decoding frame 62609 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:44:14.039858 web_php 2587 ERR socket_sendto( /var/run/zm/zms-645960s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:44:12.040067 web_php 2586 ERR socket_sendto( /var/run/zm/zms-825244s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:44:10.874287 zma_m6 2407 INF Cam2ute: 69000 - Analysing at 9.62 fps /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_monitor.cpp 1250
2015-09-04 14:44:09.046653 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 41 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:44:09.003968 zmc_m1 2395 ERR Error while decoding frame 62559 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:44:03.472358 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 3f 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:44:03.434260 zmc_m1 2395 ERR Error while decoding frame 62509 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:44:01.967159 web_php 2589 ERR socket_sendto( /var/run/zm/zms-645960s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:43:59.970784 web_php 2587 ERR socket_sendto( /var/run/zm/zms-825244s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:43:57.862601 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 3d 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:43:57.827607 zmc_m1 2395 ERR Error while decoding frame 62459 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:43:52.296334 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 3b 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:43:52.263858 zmc_m1 2395 ERR Error while decoding frame 62409 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:43:49.890927 web_php 2586 ERR socket_sendto( /var/run/zm/zms-645960s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:43:46.813904 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 39 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:43:46.766118 zmc_m1 2395 ERR Error while decoding frame 62359 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:43:44.816706 web_php 2701 ERR socket_sendto( /var/run/zm/zms-825244s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:43:41.240637 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 37 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:43:41.183738 zmc_m1 2395 ERR Error while decoding frame 62309 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:43:35.656902 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 35 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:43:35.625657 zmc_m1 2395 ERR Error while decoding frame 62259 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:43:34.560927 web_php 2590 ERR socket_sendto( /var/run/zm/zms-645960s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:43:32.752106 web_php 2694 ERR socket_sendto( /var/run/zm/zms-825244s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:43:30.111678 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 33 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:43:30.084083 zmc_m1 2395 ERR Error while decoding frame 62209 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:43:24.547840 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 31 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:43:24.503864 zmc_m1 2395 ERR Error while decoding frame 62159 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:43:22.488527 web_php 2698 ERR socket_sendto( /var/run/zm/zms-645960s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:43:20.373867 web_php 2698 ERR socket_sendto( /var/run/zm/zms-825244s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:43:18.979948 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 2f 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:43:18.943773 zmc_m1 2395 ERR Error while decoding frame 62109 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:43:13.406021 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 2d 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:43:13.363907 zmc_m1 2395 ERR Error while decoding frame 62059 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:43:10.421804 web_php 2702 ERR socket_sendto( /var/run/zm/zms-645960s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:43:08.310964 web_php 2702 ERR socket_sendto( /var/run/zm/zms-825244s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:43:07.814070 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 2b 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:43:07.783739 zmc_m1 2395 ERR Error while decoding frame 62009 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:43:07.238013 zma_m1 2402 INF Frontside: 62000 - Analysing at 8.93 fps /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_monitor.cpp 1250
2015-09-04 14:43:06.735076 zmc_m1 2395 INF Frontside: 62000 - Capturing at 9.01 fps /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_monitor.cpp 3117
2015-09-04 14:43:02.213957 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 29 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:43:02.183849 zmc_m1 2395 ERR Error while decoding frame 61959 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:42:58.358338 web_php 2589 ERR socket_sendto( /var/run/zm/zms-645960s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:42:56.707527 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 27 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:42:56.671026 zmc_m1 2395 ERR Error while decoding frame 61909 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:42:56.246608 web_php 2589 ERR socket_sendto( /var/run/zm/zms-825244s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:42:51.063388 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 25 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:42:51.025479 zmc_m1 2395 ERR Error while decoding frame 61859 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:42:47.415778 zma_m6 2407 INF Cam2ute: 68175 - Closing event 37, alarm end /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_monitor.cpp 1670
2015-09-04 14:42:47.376360 zma_m6 2407 INF Cam2ute: 68175 - Left alarm state (37) - 102(27) images /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_monitor.cpp 1665
2015-09-04 14:42:46.263907 web_php 2702 ERR socket_sendto( /var/run/zm/zms-645960s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:42:45.540663 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 23 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:42:45.503728 zmc_m1 2395 ERR Error while decoding frame 61809 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:42:42.022026 zma_m6 2407 INF Cam2ute: 68125 - Gone into alert state /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_monitor.cpp 1658
2015-09-04 14:42:40.744050 web_php 2588 ERR socket_sendto( /var/run/zm/zms-825244s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:42:39.902736 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 21 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:42:39.863813 zmc_m1 2395 ERR Error while decoding frame 61759 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:42:37.965688 zma_m6 2407 INF Cam2ute: 68111 - Opening new event 37, alarm start /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_monitor.cpp 1614
2015-09-04 14:42:37.890837 zma_m6 2407 INF Cam2ute: 68111 - Gone into alarm state /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_monitor.cpp 1568
2015-09-04 14:42:36.551521 zma_m6 2407 INF Cam2ute: 68098 - Gone into prealarm state /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_monitor.cpp 1643
2015-09-04 14:42:34.323167 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 1f 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:42:34.266016 zmc_m1 2395 ERR Error while decoding frame 61709 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:42:32.876916 web_php 2698 ERR socket_sendto( /var/run/zm/zms-645960s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:42:28.748133 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 1d 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:42:28.703778 zmc_m1 2395 ERR Error while decoding frame 61659 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:42:28.673143 web_php 2698 ERR socket_sendto( /var/run/zm/zms-825244s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:42:26.676349 zma_m6 2407 INF Cam2ute: 68000 - Analysing at 9.90 fps /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_monitor.cpp 1250
2015-09-04 14:42:23.105212 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 1b 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:42:23.063927 zmc_m1 2395 ERR Error while decoding frame 61609 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:42:20.796524 web_php 2588 ERR socket_sendto( /var/run/zm/zms-645960s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:42:17.581265 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 19 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:42:17.543710 zmc_m1 2395 ERR Error while decoding frame 61559 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:42:11.948297 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 17 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:42:11.915657 zmc_m1 2395 ERR Error while decoding frame 61509 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:42:06.424763 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 15 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:42:06.396238 zmc_m1 2395 ERR Error while decoding frame 61459 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:42:05.944607 web_php 2587 ERR socket_sendto( /var/run/zm/zms-027741s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:42:05.936676 web_php 2589 ERR socket_sendto( /var/run/zm/zms-339192s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:42:00.823729 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 13 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:42:00.794491 zmc_m1 2395 ERR Error while decoding frame 61409 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:41:55.190484 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 11 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:41:55.145574 zmc_m1 2395 ERR Error while decoding frame 61359 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:41:50.480842 web_php 3256 ERR socket_sendto( /var/run/zm/zms-027741s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:41:50.439119 web_php 2701 ERR socket_sendto( /var/run/zm/zms-339192s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:41:49.631796 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 0f 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:41:49.596284 zmc_m1 2395 ERR Error while decoding frame 61309 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:41:44.024767 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 0d 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:41:43.993886 zmc_m1 2395 ERR Error while decoding frame 61259 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:41:38.492211 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 0b 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:41:38.434061 zmc_m1 2395 ERR Error while decoding frame 61209 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:41:38.389263 web_php 2589 ERR socket_sendto( /var/run/zm/zms-027741s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:41:38.384142 web_php 2702 ERR socket_sendto( /var/run/zm/zms-339192s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2347
2015-09-04 14:41:32.857782 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 09 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:41:32.825134 zmc_m1 2395 ERR Error while decoding frame 61159 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
2015-09-04 14:41:27.315982 zmc_m1 2395 ERR 8: 00 00 01 06 e5 01 07 80 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 311
2015-09-04 14:41:27.233899 zmc_m1 2395 ERR Error while decoding frame 61109 /build/zoneminder-o0J36A/zoneminder-1.28.104-trusty/src/zm_remote_camera_rtsp.cpp 310
Can't view video after upgrading
Re: Can't view video after upgrading
If I set Options->Medium B/W->WEB_M_STREAM_METHOD to mpeg instead og jpg and go to Montage, I barely see the image flashes before it's all white. No frame, no pictures..
please go through http://www.zoneminder.com/forums/viewto ... 32&t=23375
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
Thank you very much!
