Hi all,
I recently installed Zoneminder 1.28.1 (on LinuxMint 17.2 Rafaela 64bit) and successfully got it up and running. I was rather foolishly tweaking the settings and in the "General" settings went to change the skin from "classic" to "xml". This has now rendered Zoneminder useless.
Can anyone please advise which file I need to edit, where it is located and the correct edit to revert it back to classic" skin.
Thanks,
Michael
XML
Re: XML
The (currently) 2nd post when you search for "force classic" in this forum might help
Michaeln wrote:Hi all,
Thanks,
Michael
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
