Exporting video
Zmjm15
Exporting video
Post by Zmjm15 »
Hi guys,
Just trying to export some recorded footage and i am ticking just the download video files (If present), but it just fails.
When using image files that works but downloads all the images with it, which is good but if i just wanted a straight video download, is this possible?
Many thanks
Re: Exporting video
Zmjm15
Re: Exporting video
Post by Zmjm15 »
that's awesome thanks,
Does anyone know how to change the filename that gets downloaded from zmexport.zip?
Many thanks again
Zmjm15
Re: Exporting video
Post by Zmjm15 »
In addition to this..
When exporting the images, then playing them in browser, it shows the outline of the zone which has been detecting motion, are we able to remove this at all?
Many thanks
Re: Exporting video
Turn off: CREATE_ANALYSIS_IMAGES
LBDG
Re: Exporting video
Post by LBDG »
I just finished updating a PHP script that makes videos in zoneminder c/w drop down menu and start/stop time.
I have been using it for quite a while to export videos I want to keep.
The PHP script can be found at github and is called zm-movie
(sorry cannot post links)
