Changing Web interface
Zmjm15
Post by Zmjm15 » Sun Aug 16, 2015 4:04 pm
Hi guys,
I was wondering if there was any way to change the homepage of Zoneminder, to say something like "House X", intead of Zoneminder. Also on the login to change the name as well?
Many thanks
asker
Re: Changing Web interface
Post by asker » Sun Aug 16, 2015 4:51 pm
No automatic way to do it, but its very easy.
Just edit the relevant line in login.php for the login change and console.php for the main screen change.
They are both in skins/classic/views
Note that the next time you upgrade it will get removed
Zmjm15 wrote:Hi guys,
Many thanks
PacoLM
Post by PacoLM » Sun Aug 16, 2015 5:51 pm
If you are referring to the name of the Tab when you open the zoneminder server in your web browser, then you could change it under Options:: Web::WEB_TITLE_PREFIX.
Hope it helps,
PacoLM
mini-ITX system (4 IPCams - Ubuntu20.04 - ZM1.34.15)
TelegramBot
Zmjm15
Post by Zmjm15 » Sun Aug 16, 2015 7:44 pm
Yep that's done it!
Also,
Is there anyway I can restrict a specific user from being able to see the options and log ?
Many thanks
Zmjm15
Post by Zmjm15 » Sun Aug 16, 2015 8:13 pm
Please ignore my last post I have now found it in the user's section!
Many thanks again all!
Zmjm15
Post by Zmjm15 » Sun Aug 16, 2015 9:00 pm
Actually,
Just to follow up on this,
Anyone know how to make the new "Flat" skin the default skin to use for all users?
As mine keeps defaulting back to the classic when i clear my cache out.
Many thanks!
asker
Post by asker » Sun Aug 16, 2015 9:32 pm
This used to be the case in earlier versions. To my knowledge, as of today if you go to options and select default CSS to flat it is written in the Database and if you clear your cookies it picks up the default from the DB.
Take a look at login.php around line 62 to get an idea of its order of checking for skin and its default if nothing is found.
Make sure you are on the latest version.
Zmjm15 wrote:Actually,
Many thanks!
