Connection Problems
mattionline
Connection Problems
Post by mattionline » Sat Jul 25, 2015 8:27 am
i have connection problems to my Cameras.
The pings to the Router are very nice. No package loss, but when i ping my cameras (connected over LAN) i have a 84% package loss:
root@host:~# ping 192.168.1.135
PING 192.168.1.135 (192.168.1.135) 56(84) bytes of data.
64 bytes from 192.168.1.135: icmp_seq=2 ttl=64 time=0.556 ms
64 bytes from 192.168.1.135: icmp_seq=19 ttl=64 time=1.36 ms
64 bytes from 192.168.1.135: icmp_seq=37 ttl=64 time=0.746 ms
64 bytes from 192.168.1.135: icmp_seq=38 ttl=64 time=0.649 ms
64 bytes from 192.168.1.135: icmp_seq=39 ttl=64 time=0.943 ms
64 bytes from 192.168.1.135: icmp_seq=54 ttl=64 time=9.06 ms
64 bytes from 192.168.1.135: icmp_seq=55 ttl=64 time=0.751 ms
64 bytes from 192.168.1.135: icmp_seq=56 ttl=64 time=0.619 ms
64 bytes from 192.168.1.135: icmp_seq=57 ttl=64 time=1.12 ms
64 bytes from 192.168.1.135: icmp_seq=58 ttl=64 time=0.977 ms
64 bytes from 192.168.1.135: icmp_seq=59 ttl=64 time=1.48 ms
^C
--- 192.168.1.135 ping statistics ---
70 packets transmitted, 11 received, 84% packet loss, time 69230ms
rtt min/avg/max/mdev = 0.556/1.661/9.069/2.360 ms
Could you please tell me a solution for this problem or what do you think whats the problem?
Thanks in advance
My Personal Blog: https://mattionline.de
Re: Connection Problems
Post by knight-of-ni » Sat Jul 25, 2015 1:31 pm
Bad equipment?
Bad cable?
Saturated Wifi (all it takes it 1 camera at high frame rate)?
No one can precisely answer your question, because you have not described your network topology.
To figure it out yourself, start swapping out different pieces of network equipment and cabling until you find what is causing your packet loss. The camera itself could be bad. Only by the process of elimination will you be able to figure it out.
Users browsing this forum: No registered users and 8 guests
