Linux Mint 17.2 - Zoneminder issue (SOLVED)
TrOjAn
Post by TrOjAn » Sun Jul 12, 2015 8:35 pm
Hi, just came back to Zoneminder after a spell away.
Trying to set this up and for some reason I have NO devices for Video, ie: in /dev/ I dont have any video0, video1, video2 etc etc.
I can see my card under lspci -v, part of the output is below,
05:0d.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Flags: bus master, medium devsel, latency 64, IRQ 3
Memory at d8004000 (32-bit, prefetchable)
Capabilities: <access denied>
05:0e.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Flags: bus master, medium devsel, latency 64, IRQ 19
Memory at d8003000 (32-bit, prefetchable)
05:0e.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Flags: bus master, medium devsel, latency 64, IRQ 9
Memory at d8002000 (32-bit, prefetchable)
05:0f.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Flags: bus master, medium devsel, latency 64, IRQ 16
Memory at d8001000 (32-bit, prefetchable)
05:0f.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Flags: bus master, medium devsel, latency 64, IRQ 11
Memory at d8000000 (32-bit, prefetchable)
This is in my modprobe.conf file:
options i2c-algo-bit bit_test=1
options bttv gbuffers=16 card=102,102,102,102,102,102,102,102 radio=0,0,0,0,0,0,0,0 tuner=4,4,4,4,4,4,4,4 chroma_agc=1 combfilter=2 full_luma_range=1 coring=1 autoload=0
Any help much appreciated :D
TrOjAn
chippy99
Re: Linux Mint 17.2 - Zoneminder issue
Post by chippy99 » Mon Jul 13, 2015 1:01 pm
If you type lsmod can you see that the modules (bttv and i2c-algo-bit) have loaded ?
TrOjAn
Post by TrOjAn » Mon Jul 13, 2015 3:25 pm
chippy99 wrote:If you type lsmod can you see that the modules (bttv and i2c-algo-bit) have loaded ?
Thanks for the reply... I have wiped the drive and am reinstalling from scratch.. will post the answer as soon as it boots :) I know bttv was there.. cant remember about i2c-algo-bit.
TrOjAn
TrOjAn
Post by TrOjAn » Mon Jul 13, 2015 6:59 pm
Re installed Ubuntu this time, left the card in during install and now its detected and I have the Viedo0 files etc in devs, thanks for your post anyway :)
