local video file
iomari
local video file
Post by iomari » Mon Apr 27, 2015 1:01 pm
Greetings,
I just getting my feet wet with zoneminder. I've set up a local file as source but I can't seem o get it to display. Can someone give me the steps to achieve this? The local file is a standard mpg file. Just for testing.
asker
Re: local video file
Post by asker » Mon Apr 27, 2015 1:05 pm
iomari wrote:Greetings,
If you are using source type as file, you need to point it to an image file not a video file
http://www.zoneminder.com/wiki/index.ph ... ly_support
iomari
Post by iomari » Mon Apr 27, 2015 2:10 pm
mikb
Post by mikb » Mon Apr 27, 2015 5:48 pm
If you really want to test it with a VIDEO file (for testing motion detection on a pre-recorded, predictable file), as it appears you might be doing, try this :-
I got an "mjpeg" stream from my camera into a file, and although it wasn't viewable in XINE/VLC, I used
ffmpeg -r 5 -i input.mjpeg -f avi -q:v 5 -vtag XVID -g 60 -bf 2 output.avi
to get a compliant file to look at it (output.avi)
Then I set up a new monitor called "FileTest" with Source type: FFMPEG and FPS set to 5/5 to control rate to match camera (or 25/25 to test at faster than real time) and pointed it at "input.mjpeg"
When camera is set to "monitor" or "modetect", input is processed as if it is from a camera. Return to "none" to reset and try again.
I used this with ZM when I first set it up -- having recorded a chunk of video from various cameras with a range from "known nothing" "known nothing much important" "borderline motion can u see it?" "this is motion!!" etc. examples in, makes the tuning easier if you already know the answers :)
asker
Post by asker » Thu May 07, 2015 11:54 pm
That's a nice idea mikb.
mikb wrote:If you really want to test it with a VIDEO file (for testing motion detection on a pre-recorded, predictable file), as it appears you might be doing, try this :-
