Skin problems
lsmr
Skin problems
Post by lsmr » Mon Apr 27, 2015 10:25 am
I just tried to change zoneminder skin in the options to mobile skin, but with this one don't show all the things and now I can't put the classic skin.
When I try to go to options thought: /index.php?view=options&tab=skins
Just show the message: "View 'options' does not exist" and I can't put it back.
How can I fix this??
chippy99
Re: Skin problems
Post by chippy99 » Mon Apr 27, 2015 12:41 pm
There is a cookie called zmSkin, if you delete that zm should then use default skin.
chippy99
Re: Skin problems
Post by chippy99 » Mon Apr 27, 2015 12:51 pm
Just remebered you can also do ?skin=flat or ?skin=classic at the end of your url. eg http://192.168.0.1/zm/index.php?skin=flat
asker
Re: Skin problems
Post by asker » Mon Apr 27, 2015 12:51 pm
Force it back with this:
http:/yourIP:port/zm/?skin=classic
lsmr wrote:Hi,
