Can some one point me in the direction to update to 1.28.1 from 1.28
I am still a little rusty with linux mint 17.1 on a test machine
I have the iconnor ppa zoneminder-master
I have cloned the drive just in case
Does anything need updating like the 15 sec zm run delay
Jimmy
1.28.1 update guidence
Re: 1.28.1 update guidence
I updated from 1.28 to 1.28.1 ...no problems and I've updated 3x since installation (from like 1.26.5 or something)
sudo apt-get update
sudo apt-get upgrade
I dont think you want the "iconnor ppa zoneminder-master" branch....U want the normal one ( i dont know all the lingo)
sudo apt-get update
Thank You
I tried the above with iconner-master that I have installed, no update
I then disabled the iconner-master ppa and added iconner/zoneminder ppa
Update went fine.
The reason I started with the master branch was that when I started learning zoneminder the software manager in Mint 16 I think it only gave me 1.26 I think, so I wanted to learn it on the latest version.
Thanks again
Jimmy
Update went fine.
Thanks again
Jimmy
