I'm seeing this errors in the log:
2015-02-21 12:10:10.275578 web_js 26885 ERR getStreamCmdResponse stream error: socket_sendto( /tmp/zm/zms-794230s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2015-02-21 12:10:09.956772 web_php 26885 ERR socket_sendto( /tmp/zm/zms-794230s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2330
2015-02-21 12:09:55.035798 web_js 26885 ERR getStreamCmdResponse stream error: socket_sendto( /tmp/zm/zms-794230s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2015-02-21 12:09:54.753201 web_php 26885 ERR socket_sendto( /tmp/zm/zms-794230s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2330
I added CGI to apache so I run out of options. Also installed cambozola and vlc extras.
No Video. The new page open, I see the bottons but no video
Re: No Video. The new page open, I see the bottons but no v
Bump
I see these too - but I do have video... any ideas?
OP, I actually solved the problem by doing the following:
stop zoneminder
stop apache2
wipe everything in /tmp/zm/
make sure cgi is enabled (a2enmod cgi)
start zoneminder
start apache2
The order that you start zm and apache2 is, apparently, important.
I, however, noticed another issue - I now see these messages:
I still have video and everything works but... any ideas?
stop zoneminder
stop apache2
start zoneminder
start apache2
Timed out waiting for msg /var/run/zm/zms-547954s.sock
