RTSP timing out [SOLVED]
tstrike
Post by tstrike »
Hey folks...
I was trying to stream in using RTP/RTSP but the Zoneminder collection daemon is screaming about signal dropping for a DCS 2330L.
Then I tried the HTTP stream and got a ton of errors?
2014-12-15 13:13:11.668740	zmdc	3750	ERR	'zmc -m 1' exited abnormally, exit status 255	zmdc.pl
2014-12-15 13:13:10.669401	zmc_m1	2319	ERR	Failed to capture image from monitor 1 (0/1)	zmc.cpp	267
2014-12-15 13:13:10.653101	zmc_m1	2319	ERR	Captured image does not match expected size, check width, height and colour depth	zm_monitor.cpp	2865
2014-12-15 13:13:10.439839	zmc_m1	2319	INF	Starting Capture	zmc.cpp	195
2014-12-15 13:13:09.126090	zmdc	2319	INF	'zmc -m 1' started at 14/12/15 13:13:09	zmdc.pl
2014-12-15 13:13:09.124090	zmdc	3750	INF	'zmc -m 1' starting at 14/12/15 13:13:09, pid = 2319	zmdc.pl
2014-12-15 13:13:09.067390	zmdc	3750	INF	Starting pending process, zmc -m 1	zmdc.pl
2014-12-15 13:07:47.173760	zmdc	3750	ERR	'zma -m 1' exited abnormally, exit status 255	zmdc.pl
2014-12-15 13:07:47.166032	zma_m1	2210	ERR	Shared data not initialised by capture daemon	zm_monitor.cpp	419
2014-12-15 13:07:47.123720	zmdc	2210	INF	'zma -m 1' started at 14/12/15 13:07:47	zmdc.pl
2014-12-15 13:07:47.122510	zmdc	3750	INF	'zma -m 1' starting at 14/12/15 13:07:47, pid = 2210	zmdc.pl
2014-12-15 13:07:47.063330	zmdc	3750	INF	Starting pending process, zma -m 1	zmdc.pl
2014-12-15 13:03:09.715650	zmdc	3750	ERR	'zmc -m 1' exited abnormally, exit status 255	zmdc.pl
2014-12-15 13:03:08.691411	zmc_m1	2112	ERR	Failed to capture image from monitor 1 (0/1)	zmc.cpp	267
2014-12-15 13:03:08.664689	zmc_m1	2112	ERR	Captured image does not match expected size, check width, height and colour depth	zm_monitor.cpp	2865
2014-12-15 13:03:08.516391	zmc_m1	2112	INF	Starting Capture	zmc.cpp	195
2014-12-15 13:03:07.151870	zmdc	2112	INF	'zmc -m 1' started at 14/12/15 13:03:07	zmdc.pl
2014-12-15 13:03:07.149680	zmdc	3750	INF	'zmc -m 1' starting at 14/12/15 13:03:07, pid = 2112	zmdc.pl
2014-12-15 13:03:07.096870	zmdc	3750	INF	Starting pending process, zmc -m 1	zmdc.pl
2014-12-15 12:57:47.187240	zmdc	3750	ERR	'zma -m 1' exited abnormally, exit status 255	zmdc.pl
2014-12-15 12:57:47.177341	zma_m1	2009	ERR	Shared data not initialised by capture daemon	zm_monitor.cpp	419
2014-12-15 12:57:47.136890	zmdc	2009	INF	'zma -m 1' started at 14/12/15 12:57:47	zmdc.pl
2014-12-15 12:57:47.135630	zmdc	3750	INF	'zma -m 1' starting at 14/12/15 12:57:47, pid = 2009	zmdc.pl
2014-12-15 12:57:47.091670	zmdc	3750	INF	Starting pending process, zma -m 1	zmdc.pl
2014-12-15 12:53:07.653000	zmdc	3750	ERR	'zmc -m 1' exited abnormally, exit status 255	zmdc.pl
2014-12-15 12:53:06.629384	zmc_m1	1909	ERR	Failed to capture image from monitor 1 (0/1)	zmc.cpp	267
2014-12-15 12:53:06.556200	zmc_m1	1909	ERR	Captured image does not match expected size, check width, height and colour depth	zm_monitor.cpp	2865
2014-12-15 12:53:06.403772	zmc_m1	1909	INF	Starting Capture	zmc.cpp	195
2014-12-15 12:53:05.062180	zmdc	1909	INF	'zmc -m 1' started at 14/12/15 12:53:05	zmdc.pl
2014-12-15 12:53:05.061540	zmdc	3750	INF	'zmc -m 1' starting at 14/12/15 12:53:05, pid = 1909	zmdc.pl
Any clues as to getting this to work?
tstrike
Re: RTSP timing out [SOLVED]
Post by tstrike »
I had a Duh moment.
I found the h264 stream.
I am still having problems with the capture daemon going up and down on Ubuntu. Ugh
