If perl libs are getting installed under your home folder, then it sounds like you've got the perl-local-lib package installed. This seems to be a "feature" of CentOS 7, and it needs to be uninstalled. This was discussed earlier in this thread.tcake wrote:For me the systemclt seems happy with the /etc/systemd/system/zoneminder.service file, but fails running zmpkg.pl.
Where are the perl files being installed on your Centos 7 systems? I built from source using the bootsrap.sh, configure, make, make install sequence.
My base install is going under /root/perl5. It fails when I try to run zmpkg.pl with the error that it can't find ZoneMinder.pm.
If I change the protection on /root from drwxr-x--- to drwxr-x--x it can find ZoneMinder.
I have been trying to change where the perl files get installed into a directory that is not root only protected, but so far I am lost trying to understand the bootsrap.sh / configure scripts.
Anyone got ZoneMinder working on CentOS 7?
- knight-of-ni
Re: Anyone got ZoneMinder working on CentOS 7?
