Hi
I'm running ZM 1.27. Using a FOSCAM F19804W camera.
All seems to be working apart from motion detection.
If I set it up to do motion detection the first time it's triggered it records the event then stops and waits for another event. The second time it's triggered it records the event then stops and waits for another event.
The third time the event is recorded but the recording continues and never terminates.
Anything I need to set so that it just captures the event?
DFB.
Modect continuously records on third event
- knight-of-ni
Re: Modect continuously records on third event
1) increase reference image blend %
2) lower the sensitivity of your motion detection
