Hi all, been playing around with zoneminder and enjoying it. 1.27 on ubuntu 13.10 (32bit...its on a old laptop). I'm searching around for my solution but not finding it as cut n dry as I thought. I switched the view from classic to xml, how do I switch it back?
This XML file does not appear to have any style information associated with i
Thanks in advance
Rookie Mistake with view
Re: Rookie Mistake with view
Since this was a new install I just did a quick remove and re-install, but if there was a better way I'm open to thoughts.
- knight-of-ni
Somebody just asked this a week or two ago. You should be able to search for it.
I've done the same thing myself and don't recall what the solution was exactly. It isn't very complicated.
You just stick something like "=classic" into the url or something like that.
This is what worked for me to change the interface back. I believe the URL parameters should be documented somewhere in the wiki, but I searched and found nada.
ipaddress/zm/index.php?skin=classic
