My setup as follows:
Ubuntu Server 14
ZM 1.27.99.00
Most of the time I use Google chrome and everything works perfect when viewing cameras but on one PC I'm restricted to IE 11 so I need to rely on cambozola. I have installed it and enabled it from ZM options, however when viewing an event it doesn't load up the cambozola client, but when I go to ZM options and update "Override the automatic detection of browser streaming capability" to "no" cambozla then loads and works, I would like to leave it on auto and it detect I'm in IE and load.. Is there something not setup correctly here?
Cambozola
- knight-of-ni
Re: Cambozola
Microsoft changed their User Agent string in IE11, which throws off the browser detection logic.
With the following commit ZoneMinder will now properly detect versions of Internet Explorer 11 and potentially newer. That is, unless Microsoft changes their User Agent string again.
https://github.com/ZoneMinder/ZoneMinde ... 7c2d7300da
You can safely make this change yourself on your own system by editing the appropriate file in your favorite text editor.
On another note, it seems that the latest version of Java has gone anally retentive. You will likely have to add your local zoneminder site to the site list under the Java control panel Security tab.
