Red Screen
zifth
Red Screen
Post by zifth » Sat Aug 09, 2014 3:37 am
hi, i am using 1.27 with Ubuntu 10.04. Camera configured as h.256 with ffmpeg with tcp. When first add it shows all cameras working. But after sometime some of these cameras gives a full red screen. But on top can see the camera time and date on left top corner, only the screen goes red. If i change the resolution on zm it might show again .. and later it goes red.
any help really appreciated.
Re: Red Screen
Post by bbunge » Sun Aug 10, 2014 1:00 pm
FFMPEG uses UDP by default. Forcing TCP by adding ?tcp at the end of the source may help.
You may want to upgrade to a newer version of Ubuntu as desktop support for 10.04 has ended and server support ends in April 2015. May I recommend:
http://www.zoneminder.com/wiki/index.ph ... e_easy_way
To get the libvlc to work you may have to add:
apt-get install libvlc-dev libvlccore-dev vlc
grndamgt4
Re: Red Screen
Post by grndamgt4 » Tue Sep 23, 2014 5:19 pm
Hello zifth, did you resolve this problem?
I had the same issue after upgrading but only for 2 of my cameras. The ?tcp is already on the end of the URL.
raymonvdm
Re: Red Screen
Post by raymonvdm » Tue Sep 30, 2014 9:02 am
I also seem to be having the same issue after apt updates. http://www.zoneminder.com/forums/viewto ... 31&t=22623
zifth
Re: Red Screen
Post by zifth » Thu Oct 02, 2014 1:40 pm
installed the latest ffmeg seperately, it is already with ?tcp. But still a red screen is there, some cameras are fine and some are not. No idea whats wrong. If i check without ?tcp then it shows messed up video but can see that live feed is there. Anything we could do to fix it?
