Can I disable web interface security from CLI?
tstrike
Post by tstrike » Sun Jul 27, 2014 2:09 pm
Hi all,
Its been awhile.
Apparently my Zoneminder installation webinterface is not letting me in. I checked the ZM database to verify I was using the correct password I had setup and even reset up the admin password to make sure.
Its just getting stuck at the login screen. Can I disable security via CLI?
Thanks in advance
linuxsense
Re: Can I disable web interface security from CLI?
Post by linuxsense » Mon Jul 28, 2014 12:36 am
Add:
ZM_OPT_USE_AUTH=0
to your zm.conf and restart zoneminder, should do the trick. If that fails you can change the value of ZM_OPT_USE_AUTH in the mySQL "Config" table to a "0". However, I just tested overriding it in zm.conf on one of my servers and it worked so that should be all you need. Just be sure to remove the option from the config if you want to re-enable auth.
tstrike
Post by tstrike » Mon Jul 28, 2014 7:25 pm
linuxsense wrote:Add:
ZM_OPT_USE_AUTH=0
Thank you so much. That worked for me perfectly!!! I was worried for a minute there!!!
