Analysis frames / images not being saved
kvarley
Post by kvarley »
Hi guys,
I'm experiencing an odd issue with ZoneMinder where it captures an event but stores no analysis frames for the event. I am using motion detection on zones which have the analysis method set to "Blobs" so the frames should being being saved as XX-analyse.jpg but all I get is the event frames XX-capture.jpg.
Any ideas as to how I can debug this?
Thanks,
Kev
Re: Analysis frames / images not being saved
Is CREATE_ANALYSIS_IMAGES enabled under Options?
kvarley
Post by kvarley »
knnniggett wrote:Is CREATE_ANALYSIS_IMAGES enabled under Options?
Yes it is. Analysis frames appear to be stored for some cameras but not others.
PacoLM
Post by PacoLM »
Are all the cameras in modetc mode?
kvarley
Post by kvarley »
PacoLM wrote:Are all the cameras in modetc mode?
Yep - they're all IP cameras using "Modect".
