Page 1 of 1
zmfix?
Posted: Sun Jun 08, 2014 2:46 pm
by sgharp
Hi Guys,
I've just upgraded from 1.26.x to 1.27 using the nightly master. My /etc/init.d/zonminder script calls 'zmfix -a'. zmfix doesn't exist anywhere on my machine (Ubuntu 14.04). Is this an old startup script left over from my previous 1.26 setup or did something fail to install? Is there a script that will work better with 1.27?
I'm having some other issues with image display but I want to address this first as the cause might be related.
Thanks.....
Re: zmfix?
Posted: Wed Jun 11, 2014 12:57 am
by linuxsense
I believe that zmfix is no longer used.
This init script should work for you but I have not used it on 14.04. You will at the least need to adjust ZM_PATH_BIN to point to where your ZM bins are located.
https://dl.dropboxusercontent.com/u/6511963/zm-init
Let me know how the install on 14.04 works out.
Re: zmfix?
Posted: Fri Jun 13, 2014 5:23 am
by mastertheknife
zmfix was removed in v1.27
You can safely delete the line that runs zmfix and it should work.
Re: zmfix?
Posted: Fri Jun 13, 2014 11:24 am
by sgharp
mastertheknife wrote:zmfix was removed in v1.27
Thanks but it doesn't work when I delete that line. I'm going to try the suggestion from linuxsense this weekend.
Re: zmfix?
Posted: Sat Jun 14, 2014 9:42 pm
by sgharp
linuxsense wrote:I believe that zmfix is no longer used.
This worked perfectly. Thanks very much.
