Hi Guys,
I've just upgraded from 1.26.x to 1.27 using the nightly master. My /etc/init.d/zonminder script calls 'zmfix -a'. zmfix doesn't exist anywhere on my machine (Ubuntu 14.04). Is this an old startup script left over from my previous 1.26 setup or did something fail to install? Is there a script that will work better with 1.27?
I'm having some other issues with image display but I want to address this first as the cause might be related.
Thanks.....
zmfix?
- Contact:
Re: zmfix?
I believe that zmfix is no longer used.
This init script should work for you but I have not used it on 14.04. You will at the least need to adjust ZM_PATH_BIN to point to where your ZM bins are located.
https://dl.dropboxusercontent.com/u/6511963/zm-init
Let me know how the install on 14.04 works out.
Re: zmfix?
zmfix was removed in v1.27
You can safely delete the line that runs zmfix and it should work.
Kfir Itzhak.
Re: zmfix?
Thanks but it doesn't work when I delete that line. I'm going to try the suggestion from linuxsense this weekend.mastertheknife wrote:zmfix was removed in v1.27
Re: zmfix?
This worked perfectly. Thanks very much.linuxsense wrote:I believe that zmfix is no longer used.
