Re-Adding moved events
Digitalquill
Post by Digitalquill »
All
You may have seen my last thread about the spec for a new machine, currently we are limping along with a temporary solution on a laptop and external USB disk.
Due to disk space issues I moved some days worth of events off the Zoneminder server (just moved the folders and files on command line)
Now I have a need to see those days within zoneminder so I need to add them back, I have copied the files and folders back into the correct place on zoneminder, however, the events are not showing in the interface. I assume this is due to database records being missing.
Is there anyway I can re-index those events and have them show in the interface?
In hindsight I should not have messed around like this but it was a case of needs must.
Now we have good footage of the activity we wanted to capture, but I need evidence of activity prior to the event in question, hence needing to re-add footage.
Any help would be great
Matt Houldsworth
Digitalquill
TheKorn
Re: Re-Adding moved events
Post by TheKorn »
Not aware of any way to re-add them to the database.
If you only need to re-add them so that zm can make video files out of them, another way is to load them into adobe premiere. It allows importing a sequence of numbered stills as though it was a single continuous video clip. (Probably other stuff does as well, but I'm familiar with premiere.)
PacoLM
Post by PacoLM »
TheKorn wrote:Not aware of any way to re-add them to the database.
Windows Movie Maker, free software that runs in Windows (yes, incredible, but free), allows to do the same.
