Very long duration events
basketcase
Post by basketcase » Thu May 01, 2014 9:25 am
Hey Hey,
I've upgraded to 1.27.0 for a while, and on a month view I have a number of super long duration events, that won't play back.
Most play back just fine, all my monitors are set to 300 seconds and 99% of events are just that.
then there's these:
The frame counts on the 1000+ second events are in the ball park of a 300 second events and most of my cams are 15FPS.
Any ideas why some might blow out, especially when there is no movement on the motion detection?
Cheers
Dave
TheKorn
Re: Very long duration events
Post by TheKorn » Thu May 01, 2014 12:02 pm
How many digits are you using for your image files? If it's three (the default), that's probably your problem.
basketcase
Post by basketcase » Thu May 01, 2014 12:35 pm
Not a config item I've seen before, updated to 4 as no events in the last month have more than 4500 frames.
No ill effects after a restart, will monitor ongoing.
Thanks for the tip!
PacoLM
Post by PacoLM » Thu May 01, 2014 1:07 pm
TheKorn wrote:How many digits are you using for your image files? If it's three (the default), that's probably your problem.
This does not have nothing to do...!!!
mini-ITX system (4 IPCams - Ubuntu20.04 - ZM1.34.15)
TelegramBot
