Applying State Change Please Wait
TenLeftFingers
Post by TenLeftFingers » Sun Apr 10, 2016 5:05 pm
I've installed 1.26.5 on a Raspberry Pi running Raspbian. 1.26.5 is what's included in their repo.
I followed the wiki guide (which is for Ubuntu) and with the exception of adding the iconner repo, I followed the instructions to the letter.
But the state never changes to from Stopped in the control panel. There are no logs in /var/log/zm either.
If instead of cliccking "Stopped" I click "version", I get this: "Version mismatch, system is version 1.26.5, database is ZM_DYN_DB_VERSION.
Please run zmupdate.pl to update"
zmupdate.pl fails with errors:
Bareword "ZM_PATH_LOGS" not allowed while "strickt subs" in use at /usr/share/perl5/ZoneMinder/Logger.pm line 153
BEGIN not safe after errors--complation aborted... Logger.pm line 168
Compilation failde in require at /usr/bin/zmupdate.pl line 48
BEGIN failed--compilation aborted at /usr/bin/zmupdate.pl line 48
It's a mess.. is there an 'easy way' guide that works on the raspberry pi?
Edit: also tried this raspberry pi specific tutorial but no improvement: http://www.holylinux.net/content/raspbe ... zoneminder
Re: Applying State Change Please Wait
Post by bbunge » Mon Apr 11, 2016 1:06 am
Looks like your version of Linux is based on Debian Jesse. Here is the install for Debian 8:
https://wiki.zoneminder.com/Debian_8_64 ... e_Easy_Way
What you need to do is create the database in mysql.
mysqladmin -uroot -p reload
Versions of Ubuntu prior to 15.10 created the database for ZM automatically. Debian installs had to create the database manually.
Hope this helps.
bb
TenLeftFingers
Post by TenLeftFingers » Mon Apr 11, 2016 12:06 pm
Thanks bbunge, I definitely recall running those commands and I see them in my .bash_history
When I run:
- I get: ERROR 1050 (42S01) at line 265: Table 'Logs' already exists
- I get no output after entering the password
The situation is unchanged though. I tried restarting the server as well as rebooting.
It would be great if there was a raspberry pi image set up and ready to be copied to SD.
Edit: I haven't done this part from the wiki you linked to:
deb http://http.debian.net/debian jessie-backports main in sources.list
I'll try that now.
Edit 2: only pypy-upstream is available as an upgrade from there. So Zoneminder must be the same version.
