Can't Login
mattionline
Can't Login
Post by mattionline » Fri Jul 17, 2015 3:38 pm
i have the problem that i can't login.
The username and password are autosaved by the browser, so they are correct. Im always getting forwarded to the login page when i enter my login credentials.
How can i solve the problem?
Thanks in advance
My Personal Blog: https://mattionline.de
mattionline
Re: Can't Login
Post by mattionline » Fri Jul 17, 2015 3:51 pm
I figured out that the disk storage was at 100%.
/var/cache/zoneminder took all the disk space (1TB)
I thought i got the filter, when the storage is over 95% it automatically deletes the old captures.
Gary S
Re: Can't Login
Post by Gary S » Sun Jul 19, 2015 12:34 pm
It should delete old files when it reaches your 95% full mark. Make sure you have selected "delete all matches" in your filter. I have mine set to 80%, but don't know if it works because I also have a second filter to delete anything over 30 days old, so I have never reached the 80% full mark on my drive. The 30 day filter does work every day for me.
