Corruption in my images
neek
Post by neek »
Hi, I'm seeing some strange corruption in my captured images. Not sure what's causing it, but it appears to confuse the Modect algorithm so I have events all the time.
I'm running 1.26.5 on Ubuntu 14.04LTS. My camera is an ACTi ACM-1231 (detailed info below).
Any suggestions if I have something misconfigured?
thanks,
-Nick
  • Firmware Version = A1D-220-V3.14.19-AC
    MAC Address = 00:0F:7C:02:6C:C8
    Production ID = ACM1231-09B-X-00647
    Factory Default Type = Two Ways Audio(0x71)
    Company Name = ACTi Corporation
    WEB Site = http://www.acti.com
    Profile ID = MT9M131-RB2_V080825A
    Sensor Board = MT9M131
    Video Decoder = None
    Video Processor = None
    Video Encoder = None
    PTZ_IMAGE = NONE
    NETWORK_PORTS = 1
    NETWORK_MODE = AUTO
    Unit Type = Mega IP Camera
    DI = 0
    DO = 0
    Serial Port = 0
    Platform = A
    Channels = 1
    Audio = 2
    Audio Type = PCM
    Motions = 3
    ZOOM_LENS = NONE
    VIDEO_RESOLUTION_CAP = N1280x1024,N1280x720,N640x480,N320x240,N160x112
    VIDEO_FPS_CAP = 1,2,4,8-1,2,4,8
    VIDEO_BITRATE_CAP = 28K,56K,128K,256K,384K,500K,750K,1M,1.2M,1.5M,2M,2.5M,3M
    STREAMING_METHOD_CAP = 0,1,3,4,5
    ENCODER_CAP = MJPEG,MPEG4
    VIDEO_RESOLUTION_CURRENT = N1280x1024
    VIDEO_FPS_CURRENT= MODE1,8
    VIDEO_BITRATE_CURRENT= 3M
    STREAMING_METHOD_CURRENT = 3
    ENCODER_CURRENT = MPEG4
    PROTOCOL = V2.0
    STREAMING MODE = Single Stream
    Storage = None
    DN Control = CDS
    DN Element = None
    MD_CAP = ENCODER
    MD_SRC_CURRENT = None
neek
Re: Corruption in my images
Post by neek »
Forgot to attach a sample of the corruption I'm seeing. The bottom half is the problem.
PacoLM
Post by PacoLM »
Set the maximum FPS in the camera configuration and leave the Maximum FPS and Alarm Maximum FPS empty for this monitor. Post results.
Hope it helps,
PacoLM
neek
Post by neek »
Thank you! I tried upgrading to 1.28 and now ZM can't read anything from the camera. I just posted something in the 1.28 forums to try to figure that out. If I can't get that, I'll back off to 1.26 again.
My 1.28 problem: http://www.zoneminder.com/forums/viewto ... 32&t=23200
aschmidtm
Post by aschmidtm »
neek wrote:Thank you! I tried upgrading to 1.28 and now ZM can't read anything from the camera. I just posted something in the 1.28 forums to try to figure that out. If I can't get that, I'll back off to 1.26 again.
I tried upgrading to 1.28 with the same results. No images. I downgraded and left the FPS fields blank as suggested above. It still happens, but very rarely.
PacoLM
Post by PacoLM »
From my experience, Libvlc works better than Ffmpeg in some cameras, and the opposite in another, so I recommend you to try both types of Source types in your monitors.
Hope it helps,
PacoLM
