Hi I have got the QVIS AMB-MB 1.3 Camera to work with zoneminder so thought i share it with you
this camera supports activeX, but it does work with zoneminder. to get the full url, login to the camera via web browser, once you have set the camera up, go to the live feed right click on the live feed image, then click on copy, then open a basic text editor, then past. here you will see the full url. then just paste it in source in zoneminder. i did this in linux mint, and the browser is firefox, so it might not work in other types of OS or Browser?
again, make sure you put in the correct settings in zoneminder, which can be found in the camera web interface.
hope this helps
