I am on Debian Wheezy running 1.25.0 and want to upgrade to 1.26.x
What is the general consensus of the least problematic way of doing this. Had a quick look around the forum but not too confident as to how to proceed.
Other users' experiences/advice greatly appreciated
Easiets Way to Upgrade from 1.25 to 1.26
Re: Easiets Way to Upgrade from 1.25 to 1.26
I'm also interested in 1.26 on wheezy ... has anybody running 1.26 on wheezy and can give some hints (for a newbie) how to upgrade from 1.25 to 1.26?
Thx
Thx
You might be better off just going with what is in your repository for a more stable release but depending on what you have on your system cause i dried a debian install and did okay but i like the linux mint 16 setup options out of the box its working better for me so i dont know all the differences that you can do between regular debian and say ubuntu or mint but you could try this
http://www.zoneminder.com/wiki/index.ph ... e_easy_way
there isnt anything about 1.26 yet for debian but you can check by clicking on the wiki link then on the left and then distribution specific instructions link
