error: zm requires MySQL headers... but they're there!
McFuzz
Post by McFuzz » Thu Nov 07, 2013 1:01 am
Howdy!
During the dpkg-buildpackage process, the following error message appeared:
error: zm requires MySQL headers - check that MySQL development packages are installed
I am running Percona SQL server and I do have libmysqlclient-dev installed....
Any ideas?
McFuzz
Re: error: zm requires MySQL headers... but they're there!
Post by McFuzz » Thu Nov 07, 2013 5:22 pm
mastertheknife - any ideas? This is happening when I try to use your git repo :p
mastertheknife
Post by mastertheknife » Sun Nov 10, 2013 7:24 am
Is this with cmake or autotools?
Kfir Itzhak.
McFuzz
Post by McFuzz » Sun Nov 10, 2013 10:02 am
mastertheknife wrote:Is this with cmake or autotools?
cmake
mastertheknife
Post by mastertheknife » Tue Nov 12, 2013 6:53 am
Do you have a mysql.h file in /usr/include/mysql/mysql.h ?
Kfir Itzhak.
McFuzz
Post by McFuzz » Tue Nov 12, 2013 5:18 pm
Yes I do :)
I couldn't hold on and so I've just used regular MySQL instead of Percona though I am pretty sure that if I build a new VM using the same steps, I could replicate it...
By the way - same issue happens whether I try to pull it off github or manually compile.
Users browsing this forum: No registered users and 5 guests
