- An network IP cam, a Hi3507; I have 2 others just like it
- A FoscamFI8910W
The Foscam worked first go, control and all.
The Hi3507, despite this exact camera being installed on a previous Zoneminder install and having identical settings to the other two it refuses to work.
It has successfully done my head in, resulting in tantrums, name calling of inanimate objects and lightweight items being thrown to the floor.
I press montage and all streams appear, less the new camera in question "monitor 13"
I receive these lines in the log consistently:
2013-08-31 17:53:53.124714 web_php 2942 ERR socket_sendto( /dev/shm/zms-165163s.sock ) failed: No such file or directory
2013-08-31 17:53:49.722371 web_php 3473 ERR socket_sendto( /dev/shm/zms-366441s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php
2013-08-31 17:53:46.710184 web_php 6967 ERR socket_sendto( /dev/shm/zms-366441s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php
2013-08-31 17:53:42.192843 web_php 6967 ERR socket_sendto( /dev/shm/zms-366441s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php
2013-08-31 17:53:36.787368 zms 14326 ERR Terminating, last frame sent time 1377935616.287293 secs more than maximum of 10.000000 zm_monitor.cpp
If I reset the camera, leaving Zoneminder running, my errors change:
2013-08-31 18:00:07.004554 zmc_m13 13033 ERR Unable to read packet from stream 0: error -110 zm_ffmpeg_camera.cpp 215
A red square will be displayed on the monitor.
This is short lived, the monitor will then will display nothing and show the following log messages:
2013-08-31 18:02:06.745847 web_php 4453 ERR socket_sendto( /dev/shm/zms-332326s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php
2013-08-31 18:02:02.825013 zms 14903 ERR Got unexpected memory map file size 0, expected 96001760 zm_monitor.cpp
When I look in the /dev/shm directory I can see that zm.mmap.13 exists with the other cams.
Any suggestions would be greatly appreciated, not sure if this is a bug or what?
