OrangePi and ZM
liderbug
OrangePi and ZM
Post by liderbug »
Playing with an OrangePi w camera ($19+$7) I've loaded Fedora-22 and this baby trucks. It's very responsive. apt-get installs zm.25.0. Seems the camera outputs UYVY / YUV420P. It works with fswebcam to capture and output a JPG.
I set the Palette to UYVY and the Format to PAL/NTSC/SECAM and I get:
zm_local_camera.cpp/355 [Opening video device /dev/video0]
zm_local_camera.cpp/361 [V4L2 support enabled, using V4L2 api]
zm_local_camera.cpp/366 [Checking video device capabilities]
zm_local_camera.cpp/376 [Setting up video format]
zm_local_camera.cpp/384 [ v4l2_data.fmt.type = 00000001]
zm_local_camera.cpp/385 [ v4l2_data.fmt.fmt.pix.width = 00000320]
zm_local_camera.cpp/386 [ v4l2_data.fmt.fmt.pix.height = 00000258]
zm_local_camera.cpp/387 [ v4l2_data.fmt.fmt.pix.pixelformat = 00002006]
zm_local_camera.cpp/388 [ v4l2_data.fmt.fmt.pix.field = 00000001]
zm_local_camera.cpp/389 [ v4l2_data.fmt.fmt.pix.bytesperline = 00000000]
zm_local_camera.cpp/390 [ v4l2_data.fmt.fmt.pix.sizeimage = 00000000]
zm_local_camera.cpp/391 [ v4l2_data.fmt.fmt.pix.colorspace = 00000000]
zm_local_camera.cpp/392 [ v4l2_data.fmt.fmt.pix.priv = 00000000]
zm_local_camera.cpp/411 [Failed to set video format: Operation not permit
My problem is I don't know what is wrong with the logs above.
