EnableAlarms or DisableAlarms with Command Line
shistace
Post by shistace »
I want to Enable Alarms or Disable Alarms with crontab.
Is it possible ?
For example :
All Day, 9h am : enable alarms
All Day, 18h pm : Disable alarms
asker
Re: EnableAlarms or DisableAlarms with Command Line
Post by asker »
Do you mean "enable or disable recording" based on time of day ? If so, you can easily do it via crontab. You need to create run states
http://www.zoneminder.com/wiki/index.ph ... or_week.3F
shistace wrote:I want to Enable Alarms or Disable Alarms with crontab.
Is it possible ?
For example :
Please read before posting:
ES docs
zmNinja docs
PacoLM
Post by PacoLM »
Asker, you are so kind documenting all your learnings! Good job!
asker
Post by asker »
PacoLM wrote:Asker, you are so kind documenting all your learnings! Good job!
Thank you PacoLM! I'm working on the last (and longest one) --> the zone definition article.
ES docs
zmNinja docs
