damaged install
jameswilson
damaged install
Post by jameswilson » Mon Oct 21, 2013 3:21 pm
Hi all, i have a bit of a problem. My zm has stopped functioning.
I did a distribution upgrade and during this it couldnt stop the zm service, now i have running zmc processes, but /zm/ gives page not found.
I was going to remove zoneminder and reinstall, but cos i cant stop the service i cant even remove it.
Any Ideas please?
James Wilson
Flasheart
Re: damaged install
Post by Flasheart » Mon Oct 21, 2013 6:42 pm
ps aux |grep zm
will list all zm processes, which you can then kill by the pid
Without knowing the distro, can't say other than helping with the debian 1.25 package, which is all I use.
jameswilson
Re: damaged install
Post by jameswilson » Mon Oct 21, 2013 6:44 pm
ubuntu 13.04 thanks for the reply
James Wilson
jameswilson
Re: damaged install
Post by jameswilson » Tue Oct 22, 2013 7:03 pm
as you said killed the process's and can now remove zm, but reinstallation did not fix it, i then removed agail and used the puppet module from kyle and it still dont work, any further ideas?
James Wilson
