bad source buffer hits "Time to next event = 1 seconds"
patmansf
Post by patmansf »
In case anyone else hits this problem:
For pretty much every event I looked at, I would see only one or so frames, and then I got the "Time to next event = 1 seconds", rather than the replay of the entire event, even with "gapless events" set.
My settings for the "Monitor" buffers led to hitting this problem, I set the warmup frames and others back to their original values, and it's working again.
-- Patrick
phoner
Re: bad source buffer hits "Time to next event = 1 seconds"
Post by phoner »
What settings are you using?
SteveGilvarry
Post by SteveGilvarry »
FYI the OP was posted 7 years ago.
