Problems authenticate user logins to ZoneMinder
lukeyduke
Post by lukeyduke »
I have managed to just about complete configuring Zoneminder 1.25 on CentOS 6.3. I have having problems activating the OPT_USE_AUTH option. I cannot login using the default password.
I have checked the hashed password and I am entering it correct. It is 'admin'. I am just always returned to the login page.
Has anyone encountered this before? I figure it is maybe something to do with the PHP sessions settings or a file permission.
Any help would be appreciated.
Regards,
Luke
lukeyduke
Re: Problems authenticate user logins to ZoneMinder
Post by lukeyduke »
Just in case anyone else has the same problem. Check the permissions of the PHP Sessions folder. On CentOS 6.3 this is /var/lib/php/session
ksampat
Post by ksampat »
Thanks for your post! I spent a few days trying to find the solution.
chmod 777 on the phpsessions directory did it.
