Can see recorded stills but cannot view stream
athoopen
Post by athoopen » Sun Jul 14, 2013 8:03 pm
All,
My ZM is running great however I can't replay video. I can see the stills but not the stream. The logfiles shows following error lines:
2013-07-14 21:51:48.750216 web_php 21135 ERR socket_sendto( /var/run/zm/zms-715223s.sock ) failed: No such file or directory /srv/www/htdocs/zm/includes/functions.php 2329
But I have no clue what to do or what to look for ;)
Anybody some hints or trics??
Running ZoneMinder-1.25.0-47.1.i586 on openSUSE 12.1 (32 bit)
Thanks in advance,
Arjan ten Hoopen
jHeron
Re: Can see recorded stills but cannot view stream
Post by jHeron » Mon Jul 15, 2013 7:32 pm
Check this thread http://www.zoneminder.com/forums/viewto ... 29&t=20902
Did you change the dir for events and images in the options tab? If so, you must put sim links into the standard directory linking to your preferred dir's as suggested by CKrypto towards the bottom of this thread http://www.zoneminder.com/forums/viewto ... 29&t=20902
That did the trick for me!
Good luck!
Jon
